Hello, friends.
Soon I'm going to do a job of preparing and just sending information from an ABB RW 6.xx robot to a remote computer via ethernet. I've never done this kind of work before. Does anyone have any specific literature and/or examples? Do I need any optional software for this? Thank you all.
Remote Computer
Jose Henrique -
May 7, 2024 at 1:10 AM -
Jose Henrique
May 7, 2024 at 1:15 AM Changed the title of the thread from “Remote control” to “Remote Computer”. -
what option do you have on robot controler,
NFS/FTP-client,Pc interface
what do you wish to do ,what data you need to send?
if you have nothing, you can create a log file on controler and read the file from computer in FTP
PROC WriteLogStringTest (string sStringaDati)
Open "HOME:"\File:= "DataSend.DOC", logfile\Append;
GetDateTime;
stringaWrite := sDateTime+ sStringaDati;
Write logfile, stringaWrite;
Close logfile;
ENDPROCWriteLogString " Hello:" + NumToStr(ProdCount,0);
Hi Black, thanks for your help.
I have to send production data such as type of product selected, robot cycle time, etc. Simple information that I will prepare in rapid to send via Ethernet. -
"Ethernet" is a cable. There are more than a dozen completely different data protocols that can run over that cable -- EtherCat, Ethernet/IP, ProfiNet, Interbus, TCP/IP, ModBus, UDP, FTP, etc.
So: Which one do you want to use? Which one does your robot and remote computer support? Your question cannot be answered without specifying this first.
thank you for reply...
I'll use ethrtnet IP.
EIP? All right, ABBs support that well. But how will your remote computer support it? EIP is not a normal protocol for PCs -- it used to require special ethernet cards with licensed drivers for a PC to "talk" EIP, but these days there are some pure-software solutions (CodeSys being one example). There are also some open-source implementations like https://docs.pycomm3.dev/en/latest/
which I can't say much about, since I've never used it. -
Thanks SkyeFire!
I think I'll try use the group of "SOCKET" instructions, since I'll only send information from robot to a computer. Have you use these group of instruction for this purpose before?
thanks again.
I don't think I ever used the Socket communications on an ABB, just the RS232. Which was a loooong time ago. Still, it seems to be well documented in the ABB manuals.
Looooong time ago... I know what you mean, . I'm into this also.
Thanks for your time! You take care.
