hello.
I have a R-30iB Mate Plus
I would like to use iRProgrammer in my laptop. it does not open.
Please help!
iRProgrammer
Shakhzodbek Sayidov -
March 24, 2022 at 8:14 AM -
It is a software option, You must have it installed.
Hello jpsantos96
can you tell me the name of the software? -
Hello jpsantos96
can you tell me the name of the software?Or download link?
You have to contact FANUC. Is a software option that must be installed (and paid for) on the robot itself.
Thanks!
I have got Fanuc standard educational cell. I don't know whether it contains that software option.
I think it would be a great option for programming! -
You appear to have the option to monitor not navigate. You just need the ipendant controls software its available on the CRC webpage
Check the options on your system and search for J767 (iRProgrammer). It is a free option and comes as standard with newer controllers (at least in Europe).
Hello
Thanks. I am new to Fanuc. Can you tell me how to check the options?
Click on MENU > STATUS > Version ID and then either select ORDER FI or CONFIG. The order file menu often shows packages and it is sometimes not obvious which options are part of a package.
Therefore, I normally prefer the CONFIG menu. It contains more detailed information about everything which is installed on the system.
You can also create an AoA backup and then open the SUMMARY.DG file with an editor. There you can also find the config.
I believe iRprogrammer is only available on Scara and Collaborative robots. So it is not an option for your robot.
Instead you can look into the remote ipendant option. You would need to purchase it from Fanuc.
Thanks a lot!
I have checked
There is not J767 option in CONFIG
My Fanuc is in standard educational package.
It's controller R-30iB Mate Plus supports iRProgrammer.
You are right, in the beginning of iRProgrammer that was the case. The software was basically developed to control and program SCARA robots.
However, the iRProgrammer is now a standard option installed on every robot. We explicitly order it with every FANUC robot. But this is not necessary because it became a standard (I can only say that for Europe). We have a lot of R-30iB Plus, Mate Plus and Compact Plus controllers with different robots connected and every system is equipped with the iRProgrammer option.
One of the limitations of iRPRogrammer is that it is not available or rather not compatible with older controller software versions.
Regarding the Remote iPendant option (R843), it is a really nice option for e.g. remote access. We also order the Remote iPendant option for every robot.
- Best Answer
Thanks a lot!
I have checked
It is definitely compatible with the Mate Plus controller. We have many Mate Plus with the iRProgrammer option. I would suggest asking your local FANUC rep if it is possible to get it for your controller.
What is the CRC webpage?
Customer Ressource Center, use your favorite search site and search for "Fanuc crc", would have been faster than asking here and waiting for answer.
thanks bro!
