Issues with Initial Setup / Jogging
  • ekumar
  • September 20, 2023 at 8:49 PM
  • ekumar
    27
    Hello, my company (cybersecurity company) is working on integrating with a FANUC SR-3ia robot. We are very excited and got a robot in our office! Any help in how I can get to operate/jog the robot would be much appreciated. We believed to have followed the wiring instructions correctly from the Startup Guide
    We just powered it on following the Startup Guide instructions but are unable to perform the "Jog your Robot" steps. We are able to successfully login to iRProgrammer, but we are getting error codes (shown below). If it helps here are a few other data points:
    -Under Robot Operation --> Jog, when I click an operation I get a "Please enable the TP enable key"
    -The top-right of the interface show "Auto"
    -Clicking Reset does not reset the faults
    -I also get a "Turn the Teach Pendant Enable switch to [ON]" message when trying to jog
    Note: I don't have a teach pendant.
    Here are the error codes:
    SYST-164 Teach Pendant communication error
    SRVO-001 Operator panel E-stop
    SRVO-038 Pulse mismatch (G:1 A:3)
    SYST-351 Mode select function mismatch
    SYST-212 Need to apply to DCS param
    SRVO-266 FENCE1 status abnormal
    SRVO-004 Fence open
  • 95devils September 20, 2023 at 9:35 PM
    Approved the thread.
  • DS186
    199
    1,051
    • September 20, 2023 at 11:38 PM
    Let's start with one thing at a time. Have you installed all necessary jumpers/connections, at least the jumper connections for the TP and JRT3? If you are not using the JRM18 jumper connection, have you already checked if the wiring of the external emergency stop and fence to JRM18 is correct?
    If you don't have the optional switch box and also no (hardware) remote mode switch connected to JRT3 you need to use the jumper connector for JRT3.
    Which mode selection option is installed on your controller? If you don't have one of the above hardware options for the mode selection there must be another option, e.g. TP Mode Select or External Mode Select.
    To make it easier: Could you please provide some pictures of the front of your controller and from the iRProgrammer (once you are connected to the controller).
  • ekumar
    27
    • September 22, 2023 at 2:35 PM
    Thank you for the help! I was missing the jumper connector for JRT3 so I added that. It also looked like I didn't update my software. The Software Update steps in the Startup Guide said to do this via iRProgrammer, but after talking to FANUC Support, updating the software from the factory version doesn't work that way. Anyway, I used personality 1 on the delivered USB stick and the S/W Serial No. now matches the software delivery sheet.
    While that worked, I no longer have an option for iRProgrammer in the HMI Pendant screen on the Robot Homepage. I think I took a step forward in getting the connector configuration correctly and updating the software, but have taken a step back in functionality by not having iRProgrammer.
    Any ideas on how I can get iRProgrammer back?
  • DS186
    199
    1,051
    • September 22, 2023 at 4:10 PM
    Was it possible to use the iRProgrammer before the update? Can you see any other functions in the HMI iPendant screen?
    The iRProgrammer is a separate option (J767). Can you connect to the controller without using iRProgrammer, e.g. by using a TP or Remote iPendant? If yes, you should check if the option is still installed on your controller.
  • ekumar
    27
    • September 25, 2023 at 6:13 PM
    Quote from DS186
    Thank you for the replies and patience with my responses. I was able to use IRProgrammer before the update. I can still connect to the Robot Homepage. Right now, here are the options I have under HMI iPendant:
    - Monitor iPendant (JECHO)
    - Navigate iPendant (JCGTP)
    - Jogging iPendant (JITP)
    My Software Delivery sheet has a feature for J765 and the software version reads V9.30P/29. I don't see an option for J767 on the delivery sheet.
    How can I verify J767 is installed from the Robot Homepage? FANUC support recommended I update to 9.30p/31, but I'm unsure if that will provide iRProgrammer.
    Thank you for all the help!
  • DS186
    199
    1,051
    • September 25, 2023 at 7:06 PM
    Open your Navigate iPendant and select MENU > STATUS > Version ID. You can also create an AoA backup (from the Navigate iPendant) and open the SUMMARY.DG or ORDERFIL.DAT file with a text editor and check the installed options.
    I would recommend to check the options in the SUMMARY.DG file because the order file and the delivery sheet often shows option bundles and it is not always clear what is behind them in detail.
  • DS186
    199
    1,051
    • September 25, 2023 at 7:10 PM
    Quote from ekumar
    I'm not sure if this will fix the problem. But you could try it. As always, make a full backup (Image and AoA) before.
  • ekumar
    27
    • September 25, 2023 at 8:07 PM
    Quote from DS186
    Thank you for the response. I clicked Menu in the Navigate iPendant screen but I did not have a STATUS option. Below is a the top portion of the Summary Configuration / Status from the Current Robot Status tab in the Robot Homepage.
    F Number: <REDACTED>
    VERSION : LR HandlingTool
    $VERSION: V9.30241 4/5/2023
    DATE: 25-SEP-23 14:03
    VERSION INFORMATION::
    SOFTWARE: ID:
    LR HandlingTool 7DF3/29
    S/W Serial No. : <REDACTED>
    Controller ID : <REDACTED>
    Robot No. : <REDACTED>
    Manufacturing ID :
    SR-3iA, LR HandlingTool
    SR-3iA V9.30P/29
    Servo Code : 1234567890
    Cart. Mot. Parameter: V3.00
    JNT. Mot. Parameter : V3.00
    DCS : V0.0
    Stop pattern :
    Software Edition No.: V9.30P/29
    Update Version : None
    Customization Ver. : None
    Root Version : V9.30241
    Boot MONITOR : V9.40P/32
    Teach Pendant : 7D0A/01P
    Browser Plugins : H]”:f¬:f¨V9.30241
    TP Core Firmware :
    TP Operating System :
    HTML5 Browser : N/A
    FPGA Version : 15
    Media from FRA 04/10/2023
    CONFIG::
    FEATURE: ORD NO:
    LR HandlingTool H551
    English Dictionary H521
    4D Standard R782
    Analog I/O H550
    Angle Shift J614
    Auto Software Update ATUP
    Automatic Backup J545
    Background Editing J616
    Camera I/F VCAM
    Common calib UIF CUIF
    Condition Monitor J628
    Control Reliable CNRE
    DHCP R526
    Data Acquisition R631
    Diagnostic log RSCH
    Displaying License LICE
    Document Viewer DOCV
    Dual Check Safety UIF DCSU
    Enhanced UIF R869
    Enhanced User Frame J604
    Ext. DIO Config EIOC
    Extended Error Log R542
    Extended User Frames R696
    External DI BWD ESET
    FCTN Menu Save J516
    FTP Interface J716
    GigE Interface R681
    Group Mask Exchange MASK
    HTTP Proxy Svr PRXY
    High-Speed Skip J627
    Host Communications HOCO
    Hour Meter J513
    I/O Interconnect 2 J542
    Incr Instruction J510
    Incremental Jog J637
    KAREL Cmd. Language J650
    KAREL Run-Time Env J539
    Kernel + Basic S/W H510
    License Checker LCHK
    LogBook(System) OPLG
    MACROs, Skip/Offset J503
    MH Core MHCR
    MMR Motion log PSLG
    Mate controller MATE
    MechStop Protection MCSP
    Mirror Shift J506
    Mixed logic J554
    Mode Switch MDSW
    Motion Diag. Core MDCO
    Motion Optm. Core OPCO
    Motion Profiler MPRO
    Motion logger R637
    Multi-Tasking J600
    PCM function PCMF
    Palletizing J500
    Position Registers J514
    Print Function J507
    Prog Num Selection J515
    Program Adjust J517
    Program Shift J505
    Program Status PRST
    Program Viewer J697
    RDM Robot Discovery FRDM
    Realtime Freq Anlys FREQ
    Remote Conn Standard RMCN
    Robot Servo Code H930
    SNPX basic SNBA
    SNTP Client R610
    Shift Library SHLB
    Shift and Mirror Lib SMLB
    Socket Messaging R636
    TCP Auto Set J520
    TCP/IP Interface HTCP
    TMILIB Interface TMIL
    TP Firmware R789
    TP Menu Accounting TPAC
    TPTX TPTX
    Telnet Interface TELN
    Tool Offset J509
    Torque Simulator I/F J882
    Touch Panel R781
    Trouble Diag. & Prev. J958
    Tutorial TUTO
    USR EVNT UEVT
    Unexcepted motn Check UECK
    User Frame UFRM
    VCalibration Common VCCM
    Vision Core VCOR
    Vision Library VIPL
    Vision SP CSCX CSCX
    Vision SP CSGE CSGE
    Vision SP CSUI CSUI
    Web Plus WEBP
    Web Server HTTP
    Web Svr Enhancements R626
    ZDT Application R882
    ZDT EOAT Setup ATUI
    iPendant CGTP
    iPendant Grid Display IGUI
    iPendant Setup IPGS
    iRCalib. Standard IRCL
    iRDiag Core DGCO
    SR-3iA H745
    Alarm Cause/Remedy R665
    Collision Guard R534
    Collision Guard Pack J684
    Compact Controller J765
    Constant Path R663
    Cycle Time Priority J523
    DCS Joint Pos check DCSJ
    FRA Params R650
    HMI Device (SNPX) R553
    Jog in Auto Mode R694
    NRTL J547
    Online Help R664
    PC Remote iPendant R850
    Password Protection J541
    Persistent Strg NVDT
    ROS Ethernet Packets R603
    Remote iPendant R843
    Smooth Stop Upgrade J548
    iRProgrammer J767
    64MB DRAM D064
    64MB FROM F064
    Cell I/O CLIO
    Common shell R645
    Common shell core CMSC
    Common softpanel CMSP
    Common style select STYL
    Cycle time Opt. CTOP
    DCS Pos./speed common DCSC
    Demo Control R769
    Email Client JNN7
    Enhanced Rob Serv Req ORSR
    Enhanced T1 Mode R680
    Include Remote TP JCGT
    Linear Distance R633
    MR Standard MRST
    No memory card NOMC
    OPC-UA OPCU
    Robot Library Setup RLCM
    Robot Service Request SRSR
    SCARA Robot SCRA
    SSPC error text ETSS
    Smooth Stop common SMSC
    Space Check J609
  • ekumar
    27
    • September 25, 2023 at 8:25 PM
    I'll also add that if I click the Note tab on the Robot Homepage it reads iPendant Controls not detected. Not sure if this is related, but wanted to share.
    I downloaded iPendant Controls V9.30 B and ran the setup.exe file on the PC that I'm opening up the Robot Homepage Web Browser from.
    Edited once, last by ekumar (September 25, 2023 at 8:57 PM).
  • DS186
    199
    1,051
    • September 25, 2023 at 9:07 PM
    Quote from ekumar
    STATUS is on the second MENU page. For this, click MENU > 0 - NEXT > STATUS.
    Quote from ekumar
    iRProgrammer J767
    Thanks for providing the summary file. The iRProgrammer is still on your system.
    I'm not aware of any variable or procedure to hide the iRProgrammer (icon). What Browser do you use to access the robot web server? Google Chrome (from V31) and Internet Explorer 11 are recommend and supported.
    Did you already try to update the software as suggested by FANUC?
  • ekumar
    27
    • September 26, 2023 at 5:21 PM
    • #11
    Quote from DS186
    I clicked NEXT as well but didn't see STATUS. Oh well, since I think the other information I provided helped.
    Quote
    I accessed the Robot Homepage from Google Chrome and ran into the same issue.
    FANUC requested I take a backup and send them the information. Once I get a procedure from them, I'll go ahead and send them a backup. Otherwise, I'm not sure what other next steps I can do at this point.
    I have not done an incremental software update from v29 to v31. Unsure if that will resolve the issue since the first software update didn't.
  • DS186
    199
    1,051
    • September 26, 2023 at 5:46 PM
    • #12
    Quote from ekumar
    I guess that would be best in this case. It would be nice if you can share any update regarding this topic.
  • ekumar
    27
    • September 26, 2023 at 6:39 PM
    • #13
    Quote from DS186
    I plan to update as I progress!
  • ekumar
    27
    • September 26, 2023 at 10:20 PM
    • #14
    The fix was simple. It was in a controlled start and it needed to be switched to a cold start.
    I was able to job but now I'm getting an MOTN-049 Attempt to move w/o calibrated. Any idea how this could happen?
  • pdl
    266
    1,506
    • September 26, 2023 at 11:15 PM
    • #15
    Try setting $DMR_GRP.$MASTER_DONE to TRUE and then calibrate from the Master/Cal screen.
  • DS186
    199
    1,051
    • September 26, 2023 at 11:35 PM
    • #16
    Quote from ekumar
    Oh wow, the most obvious and simplest solution... Never thought about that in this case. Although, performing a cold start should always be the starting point of a "good" troubleshooting :grinning_face_with_smiling_eyes:
    Quote from ekumar
    Being in controlled start mode also explains this.
    Quote from ekumar
    Do you only have the MOTN-049 alarm? Did you check the alarm log for any other alarms (e.g. SRVO-038, SRVO-075, etc.)?
    If there is only MOTN-049 then set the system variable $MASTER_ENB to 1 and also check if $DMR_GRP[1].$MASTER_DONE is TRUE. Select MENU > 0 - NEXT > SYSTEM > Master/Cal. Select CALIBRATE > Yes and finally click DONE. Jog the robot to its zero position (all witness marks should be aligned). Open the position window and verify if the values of all axes is 0.
  • ekumar
    27
    • September 26, 2023 at 11:45 PM
    • #17
    Hi all, I called support and we got this resolved. We set the MASTER_COUN variables to what it says in the inspection sheet. Great to see the robot moving (again)!
