MRC SK16 Second starting position
  • valkamar
  • March 25, 2024 at 10:24 AM
  • valkamar
    57
    Yasnac Motoman Sk16 MRC
    Second starting position - why is it done, how is it done and where should the robot be?
  • 95devils
    235
    8
    1,951
    • March 25, 2024 at 10:36 AM
    Thread
    Second home position
    I know that the second home position must be done after error 4107 and I know that this position can be set manually, i.e. modified. What is its purpose and benefit? we have to have a point in space or can it commute anywhere while checking?
    Kate Harris
    May 12, 2023 at 8:43 AM
  • valkamar
    57
    • March 27, 2024 at 7:33 PM
    Robot in the Main Menu.
    How to find : Robot in the main menu:
  • TSGIR
    81
    715
    • March 28, 2024 at 6:36 AM
    The MRC controller is very old and Yaskawa don't support it.
    I attached a document for MRS+SK16, i hope it can help you.
    Files
    SK16 133680-3_111907.pdf 12.03 MB – 30 Downloads
  • valkamar
    57
    • March 28, 2024 at 6:57 AM
    How do I find a second starting position?
    Where is this main menu?
  • 95devils
    235
    8
    1,951
    • March 28, 2024 at 10:43 AM
    Quote from valkamar
    See starting at page 132 of the manual TSGIR posted above.
    You don’t have a Main Menu. Only controllers in the past 20 years have it.
  • valkamar
    57
    • March 28, 2024 at 5:44 PM
    ОК
  • Robodoc
    56
    7
    1,061
    • March 31, 2024 at 2:28 PM
    in MRC it's called "Specified point". The alarm is not 4107 in MRC, 4107 only comes up on robots with an Main menu or top menu button. I don't remember what the alarms is for "Check specified point". The 'F' key for 'Spec Point' is either under Customer or function. You can change it to anything you like, it does not effect the running of the robot or the calibration of the arm to the controller.
    Robodoc
  • valkamar
    57
    • March 31, 2024 at 3:52 PM
    Thanks Robodk,
    Where is the SK16 battery located, when should it be replaced, so as not to lose memory and require a reinstallation. I know about the robot, but I don't know where it is on the CONTROLLER.
  • roboprof
    24
    473
    • April 1, 2024 at 4:27 PM
    There are 2 batteries inside the controller. One for SYSTEM DATA, one for ABSO DATA. They are labelled on the gold plate. There is also an encoder battery inside the base of the robot arm.
  • valkamar
    57
    • April 1, 2024 at 11:10 PM
    • #11
    When are the batteries changed when the controller is on or off?
    It is known where the robot's battery is, but not clear about the controller.
    Does it indicate that it is due for replacement?
  • roboprof
    24
    473
    • April 2, 2024 at 2:07 PM
    • #12
    You will get messages saying "MEMORY BATTERY WEAK" or "ENCODER BATTERY WEAK". You can use a multimeter to check battery voltage. If it drops below 3v, change the batteries.
    Recommend that you change the batteries every 3 years. Also change batteries with power on.
  • valkamar
    57
    • April 2, 2024 at 6:57 PM
    • #13
    When I turn on the pendant I should get these messages without looking at any menu. at the top right end of the pendant. The batteries have not been changed for more than 5 years!
    Can you detail how to locate these batteries in the controller.
  • roboprof
    24
    473
    • April 3, 2024 at 1:32 PM
    • #14
    No the messages will show up in the message line at the bottom of the pendant.
    The two batteries in the controller are easy to replace. Just keep the controller power on and replace the batteries. They have a 5 pin system.
    The controller battery in the base of the robot is trickier. With power on, you need to take the back cover off the base, find the old battery, find the connections for the new battery, and plug in the new and replace the old. Then put the cover back on.
  • valkamar
    57
    • April 4, 2024 at 5:46 PM
    • #15
    Hi ROBOPROF,
    There is an inscription on the dashboard
    SYSTEM
    bat
    alm
    there is a light diode available that does not light up.
    Is the battery in this board?
  • roboprof
    24
    473
    • April 5, 2024 at 3:22 PM
    • #16
    Yes, there should be a battery there. You may need to take off the cover to get to the batteries.
  • valkamar
    57
    • April 5, 2024 at 9:01 PM
    • #17
    ОК!
  • valkamar
    57
    • April 9, 2025 at 7:23 AM
    • #18
    What are the battery specifications: voltage. milliamps for charging /do not overload the charger/
  • roboprof
    24
    473
    • April 11, 2025 at 3:54 PM
    • #19
    3.6 volt Toshiba Lithium batteries. You can buy directly from Yaskawa.
  • Robodoc
    56
    7
    1,061
    • April 12, 2025 at 2:11 PM
    • #20
    These are not rechargeable batteries.
    There is a resistor and a diode in the battery case to avoid dead short problems.
    Use ONLY batteries from Yaskawa for your robots!
    Robodoc
