BAS(#TOOL,1) vs $ACT_TOOL=1
  • sloopkogel
  • March 19, 2024 at 6:45 AM
  • sloopkogel
    34
    What is the difference in the 2 following examples, and why would you choose one over the other:
    example 1:
    BAS(#TOOL,1)
    example 2:
    $TOOL=TOOL_DATA[1]
    $ACT_TOOL=1
  • Go to Best Answer
  • hermann
    404
    2,595
    • March 19, 2024 at 7:04 AM
    The code of bas is readable, you can have a look into it and check by yourself what the difference is. :winking_face:
  • sloopkogel
    34
    • March 19, 2024 at 9:24 AM
    Thanks for your reply. I took a peek in BAS.src and it seems that using BAS(#TOOL,1) also sets $LOAD variables according to the tool number
    Am I correct in thinking that using example 2 in my previous post would be more suitable for most cases? (eg. moving robot to a given point without using ILF)
  • hermann
    404
    2,595
    • March 19, 2024 at 9:29 AM
    I don't think that example 2 is the better way.
    You checked that the first example also sets the load, I think load should also be set when you don't use ILF, don't You?
  • Roland Keller
    5
    60
    • March 19, 2024 at 9:33 AM
    With $TOOL = TOOL_DATA[1] you move the robot without load data when you write the move command in KRL
    Edit says
    oops Hermann was faster
  • sloopkogel
    34
    • March 19, 2024 at 12:03 PM
    Quote from hermann
    Oops! I meant to say example 1 is the better way
    SkyeFire
    1,038
    9,375
    • March 19, 2024 at 2:05 PM
    • Best Answer
    Using BAS is convenient, but not necessary. KUKA included BAS mostly to support Inline Form programming. As you've seen, setting the Tool with BAS automatically sets $ACT_TOOL and $LOAD, along with $TOOL. This allows Inline Form motion points to only select a Tool number and let BAS do everything else for them.
    As far as I am aware, $ACT_TOOL has no effect on the robot, it just updates the "active tool" number shown in the pendant display. If you control $TOOL directly, it's possible to forget to update $ACT_TOOL, so the pendant display will not match your actual active tool.
    OTOH, avoiding BAS lets you do things like change $LOAD when you pick/drop a payload without needing to set up duplicate Tools (Tool 1 for an empty gripper, Tool 2 for a full gripper, with identical XYZABC but different LOAD_DATA values). It's also handy if, for some reason, you don't want to use the TOOL_DATA array.
    Most of the time, BAS is the better option. But KRL allows you the flexibility to choose.
  • sloopkogel
    34
    • March 21, 2024 at 12:39 PM
    One more question: I have a robot with an external axis (E1), and there at a certain point I want to move only that axis. I have done this with the following code:
    StartPos = $pos_act
    StartPos.E1 = 30.0
    ;FOLD SPTP StartPos Vel=10 % PDAT1 Tool[1] Base[17] ;%{PE}
    ;FOLD Parameters ;%{h}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.PointName=StartPos; Kuka.BlendingEnabled=False; Kuka.MoveDataPtpName=PDAT1; Kuka.VelocityPtp=100; Kuka.VelocityFieldEnabled=True; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
    ;ENDFOLD
    SPTP XStartPos WITH $VEL_AXIS[1] = SVEL_JOINT(100.0), $TOOL = STOOL2(FStartPos), $BASE = SBASE(FStartPos.BASE_NO), $IPO_MODE = SIPO_MODE(FStartPos.IPO_FRAME), $LOAD = SLOAD(FStartPos.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT1), $APO = SAPO_PTP(PPDAT1), $GEAR_JERK[1] = SGEAR_JERK(PPDAT1), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
    ;ENDFOLD
    This works fine
    This also works, but E1 is rotating extremely slow:
    StartPos = $pos_act
    StartPos.E1 = 30.0
    BAS(#VEL_PTP,30)
    BAS(#ACC_PTP,30)
    BAS(#TOOL,1)
    BAS(#BASE,17)
    PTP StartPos
    Is there something else I need to do to initialize speed for axis E1? Something that is happening in the inline form that I'm skipping?
Similar Threads
  • MANY DIFFERNT LOADING DATA FOR A SINGLE TOOL
    • IlFincoITA
    • September 17, 2021 at 9:07 AM
    • KUKA Robot Forum
  • array/grid-wise measurement with kuka robot
    • El_Mo
    • June 25, 2022 at 3:43 PM
    • KUKA Robot Forum
  • Not linear trajectory
    • Vlad222
    • July 28, 2020 at 4:02 PM
    • KUKA Robot Forum
