  4. Kawasaki Robot Forum
Restarting the main program
  • robocoder
  • March 17, 2024 at 2:07 PM
  • robocoder
    5
    51
    Hi!
    I need a way to go back to eg. line 10 of the main program before the main loop starts (an alternative may be to restart the main program entirely). This also needs to work from any called subprograms.
    MAIN PROGRAM
      INSTRUCTION1
      INSTRUCTION2
      ; Place to restart from
      ONI resetSignal CALL InterruptProgram
      INSTRUCTION3
    CYCLE:
      ; Main-loop
      CALL SubProgram ()
    GOTO CYCLE
    I have thought about the following solutions and wonder what you may consider the most proper way of doing it or if you have any input:
    One solution may be to monitor the signal in a PC program, eg.
    PC PROGRAM
      ; Alternative 1
      IF SIG (resetSignal) THEN
        BRAKE
        HOLD
        KILL
        PRIME Main, -1
        CONTINUE
      END
      ; Alternative 2
        BRAKE
        JUMP MainProgram
      END
    I feel the first alternative is kind of a hack as it resets the execution stack which I feel is unnecessary? Alternative 2 feels more proper in a way? Another solution may be to use an ONI instruction and replicate the same ONI instruction in every subprogram called from the main program.
    MAINPROGRAM
    SUBPROGRAM
    INTERRUPTPROGRAM
    BRAKE
    JUMP MainProgram
    The problem now is that I have to remember to put ONI instructions in every subprogram. The JUMP instruction also mentions that it may not jump to the source program, but I guess by calling it from within the InterruptProgram it might work as the MainProgram is then no longer the source program.
    I am not able to test this right now so I am just asking to verify if I am on the right track or if I should do something different that is more "proper".
    Thank you very much and sorry for the long post!
  • kwakisaki
    694
    4,770
    • March 17, 2024 at 4:14 PM
    Quote from robocoder
    Why?
  • robocoder
    5
    51
    • March 17, 2024 at 5:32 PM
    I need to be able to cancel the current task (eg. if a box is dropped) and then go back to start and grab the next box.
    I can solve the go back to line 10 by moving the lines above in a separate program (eg. initialize). then initialize calls the main program.
  • Alexandru
    49
    407
    • March 17, 2024 at 7:18 PM
    Is not mandatory to restart the program if, the robot dropped the box. You might have 2 options:
    1. The robot can continue the motions (for example there is no enough vacuum level and the box is still in the gripper, the operator placed the box in the gripper)
    2. The robot can pick another box (in this case, just make the program in such a way that the robot is able to go back at picking position)
  • saberlars
    Robot, beyond Human..
    22
    225
    • March 17, 2024 at 8:19 PM
    There is no need to terminate the Program's Task. This is because you can exit again using Return instruction when the Sub Program is called.
    In general, forcefully terminating a task is mainly used for emergency situations such as forced homing or special event handlers. You don't need to consider it during normal automatic startup.
    ABB, FANUC, Hyundai, Kawasaki
  • kwakisaki
    694
    4,770
    • March 17, 2024 at 9:10 PM
    So where is the location of the dropped box can you ensure the following:
    - Does it interfere with further robot motion.
    - Does it interfere with other cell peripheral operations.
    - Does it prevent the next box in from getting to the picked position.
    - Does it still remain in a position to be picked again.
    Not everything is solved with automatic return to pick next box.
    At some point, someone will need to clean up the mess of dropped boxes and ask questions.
    - Why was the box dropped in the first place - can this be engineered out instead.
    Consider creating not only a pick motion subroutine only, but also a gripper activation subroutine and gripper check subroutine with 'constant loop traps'.
    This way you can create simple checks and trap inside gripper subroutines using TIMERS/UTIMERS and PAUSES.
    Remember programming is about getting the operation working, not about elegance.
    Interrupts should be carefully studied in the AS Manual as there are several flavours with differences.
    An interrupt wants to return to the point of interruption.
    Consider this in relation to signal states, but importantly for return robot paths and trajectories.
    It is easy to implement an interrupt and also as easy to neglect the return path from the interrupt and wipe things out.
    Of course, an interrupt does not have to include a motion segment, just a simple pause command will do and upon pressing cycle start again, it will return to where it was interrupted from which will be the same place and can be just as effective as 'constant loop trap routines'.
Similar Threads
  • Condition monitoring question
    • TitusLepic
    • April 28, 2023 at 6:54 PM
    • Fanuc Robot Forum
  • Touch sensing in Arc weld robot
    • arun_AR
    • September 30, 2021 at 5:44 PM
    • Kawasaki Robot Forum
  • Help With BG Logic/User Alarms
    • AutoMattic21
    • May 16, 2022 at 8:36 PM
    • Fanuc Robot Forum
  • KSS Main screen
    • Gocea
    • November 29, 2021 at 9:01 PM
    • KUKA Robot Forum
  • Constrain TCP in B and C movement due to singularities at axis 4. Tool is not allowed to be tilted in axis B and C doing movement, but direct SLIN movement causes singularities.
    • ChristianLiinHansen
    • January 17, 2022 at 11:36 AM
    • KUKA Robot Forum
  • Movement for home position
    • Neverine
    • November 2, 2021 at 7:17 AM
    • ABB Robot Forum
  • Sporadic EKI and Internal file error.
    • Joe Muller
    • July 15, 2020 at 7:32 PM
    • KUKA Robot Forum
  • HIGH SPEED UNCOMMANDED MOVE - KAWASAKI CP180
    • jeremyk
    • July 6, 2017 at 10:35 AM
  • Kawasaki E Controller
