Accurate part pick up
  • ToucanSam
  • January 22, 2024 at 7:00 PM
  • ToucanSam
    Hello, total newbie here
    We are wanting to set up an arm here for machine tending. We have a Fanuc 2d iRvision camera that we plan to use to locate the parts.
    We are working with round aluminum castings here that have imperfections on the faces, so they do not necessarily sit quite flat especially if they are stacked.
    What is the best way to compensate for that. I see Schunk for example, sells compensation units. Is that the correct direction for me to look into, or is there something else I should be looking at.
    Any info is helpful, thanks.
  • Werner Hampel January 22, 2024 at 7:29 PM
    Approved the thread.
  • TygerDawg
    187
    • January 27, 2024 at 5:01 PM
    Does "machine tending" mean "machine tool load & unload"?
    If so, then the cycle time is probably a sufficiently-long duration. Then it may be possible to incorporate a place/re-position/re-grip sequence of steps that may mechanically give you the grip accuracy you need.
    TygerDawg
    Blue Technik
    http://www.bluetechnik.com
    SkyeFire
    1,051
    9,421
    • January 27, 2024 at 5:10 PM
    Your vision is going to have a limit on how accurately it can measure anything, and rough castings are particularly bad. You'll need to determine the error range of your camera vs the castings, then design your end effector to allow for that much inaccuracy. Grippers that have extra open/close range, for example, and maybe with grip-force or full-range feedback instead of simple open/close sensors, for example.
    In addition to that, 2D vision only gives X,Y, and Rz corrections. So your casting that don't sit level will have Rx and Ry variance that your gripper will have to tolerate. This can be done multiple ways -- for example, an array of vacuum cups with deep bellows is one of the simplest solutions. If that's not workable, it becomes a question of how your gripper engages the casting. If you're just gripping it from the sides, then the tilt might be irrelevant (depending on if you need to correct for the tilt before (I assume) placing the casting into the milling machine). If not, this becomes a question of which surface of the casting you're trying to align the robot to. If the top surface, then you could use Force-Torque sensing. Or, I've seen setups that used three long-stroke "plunger" sensors arranged in a circle, and as they made contact with the top of the part, did trigonometry to calculate a corrective rotation until all three sensors had the same reading.
  • panic mode
    1,278
    13,074
    • January 27, 2024 at 7:55 PM
    Quote from TygerDawg
    It means robot is attendant and as such is attending to machine needs in order to keep machine running. normally this means loading/unloading but it could be something else like cleaning, swapping tooling or nesting, probing/measuring, flipping parts etc. The degree of automation can vary but robot is there to replace human in interacting with the machine.
Similar Threads
  • Part tilt & rotation throwing off pick coords
    • asdf
    • October 10, 2023 at 6:04 PM
    • Robot Vision and Vision Products
  • iRVision - Accuracy changes with Part Rotation
    • AlexMac
    • July 29, 2023 at 7:52 AM
    • Fanuc Robot Forum
  • Kinda Lost between all of those options
    • Robot2
    • July 3, 2023 at 10:36 AM
    • KUKA Robot Forum
  • VisionTech Calibration Grids
    • SkyeFire
    • May 9, 2018 at 4:57 PM
    • KUKA Robot Forum
  • Deburring Process broken
    • OpaBroesel
    • November 9, 2022 at 8:10 AM
    • KUKA Robot Forum
  • Fanuc 2D vision 100+ Part Types
    • McNorgs
    • June 17, 2021 at 2:49 PM
    • Fanuc Robot Forum
  • Timing analysis
    • Affaltar
    • July 14, 2020 at 9:27 AM
    • General Discussion of Industrial Robots Only
  • Vision Guided Robot System Help Please!!
    • steveo86
    • January 26, 2020 at 2:16 PM
    • Yaskawa Motoman Robot Forum
  • Fanuc iRVision Off-Axis Rotation Correction
    • Nick1324
    • January 14, 2020 at 5:21 PM
    • Fanuc Robot Forum
