Hi everybody
I have a problem between my plc and robot. I have a siemens plc s1500 and a fanuc robot, im trying to comunicate them with ethernet ip. I have follow all the steps but i cant comunicate the plc with the robot, both of them are in the same ip range and i can ping each one from the computer. Also i can ping the plc from the robot. The plc is the scanner and the robot is the adapter
In the Fanuc robot, the ethernet ip connection is online but not running. I have checked all the EDS data from the robot and i am sending thease values correctly from the plc. Also the tcp/ip connection has been initialized.
¿Could someone help me?
I would like to know at least if the problem is in the robot configuration or in the plc.
Thanks very much
