I need to perform the brake test on my robot, but I'm encountering issues. The attempt to execute it results in a failure with the code KSS02848. I am using version 8.3 of the KSS software. Any suggestions on how to resolve this problem? Thank you!
Break test
Paulo06 -
May 30, 2023 at 3:41 PM -
95devils
May 30, 2023 at 3:45 PM Approved the thread. -
It would help to have the complete text of the error message, since most of us can't memorize the entire multi-thousand list of error codes.
It would also help to know how you are attempting the Brake Test, and see the code that is throwing that error message.
KSS02848 MDR: Unknown device name BRAKE_TEST.
Originator: /R1/BRAKETESTREQI am trying to execute the program "braketestreq" on T1.
Use forum search with keyword motiondrv.ini for additional info on how to activate brake test driver manually.
Fubini
Not possible. Brake Test cannot be executed in T1 -- only in the full-speed modes: T2, AUT, or EXT.
This is not causing your error message, but once you have fixed that using Fubini's suggestion, you will have to run Brake Test in one of the full-speed modes.
