Hi All,
I have a KR 210 L with KRC2 controller V 5.4. I am using it for some temporary additive applications with the help of an extruder.
I normally generate tool path in Rhino-Grasshopper and transfer the SRC file to R1 folder using a pen drive. But when the file size is bigger (in this case 1800KB), I am not able to copy it to the controller, also it doesn't throw any errors.
Is there any work around to make it possible? What is the size limit for a single SRC file?
is there any other way to transfer (more like export) files to the controller considering the version I am using?
Also the robot stops every 2 hours with brake test error, which I normally acknowledge and continue the paused program. Can we remove it? as some prints take more than 5 hours and it needs to run without a break as extruder's response is not as quick, it ruins the resolution of the print.
Please let me know if you need more data to help me with the mentioned issues.
Thank you
