Gripper for tiny components 1-3mm
  • Reckless
  • May 6, 2023 at 1:41 PM
  • Reckless
    104
    What is the best gripper to pickup tiny components? Looking to find one gripper with 1mm nozzle but also be able to pickup 30mm objects (under an ounce).
  • Go to Best Answer
  • Motouser
    39
    288
    • May 8, 2023 at 11:22 AM
    "IRONIC COMMENT: NO OFFENSE"
    Millimeter + Ounce. What Kind of measure systems are you using???
    Why the world (americans/british) are so complicated. :wallbash: :wallbash: :wallbash: :wallbash:
    SkyeFire
    1,051
    9,423
    • May 8, 2023 at 5:05 PM
    Quote from Reckless
    What kind of gripper? Fingers? Vacuum? What kind of material -- hard, soft, porous, etc?
  • Lemster68
    299
    2,467
    Blog Articles
    7
    • May 8, 2023 at 9:38 PM
    Is the material possibly attracted to a magnet?
    panic mode
    1,278
    13,079
    • May 8, 2023 at 9:52 PM
    I think he is looking for something to use in PCB assembly. The small parts are various components, mostly SMD...
    SkyeFire
    1,051
    9,423
    • May 9, 2023 at 3:48 PM
    • Best Answer
    Quote from panic mode
    That would make sense. And not be an easy problem to solve. Most SMD pick&place machines I'm aware of (this isn't my field) use a very tiny vacuum cup for most components, since most SMD parts have a (very small) flat top that can be grabbed this way.
    But since SMD components require very precise X,Y, and Rz location, you need a way to ensure the part is picked properly, and that the vacuum cup doesn't cause any rotation of the part when "sucking up". Which, with parts that small and with such a variety of shapes and sizes, can be quite difficult.
    A 1mm vacuum cup that can also pick up a 30mm PCB, though... I don't think that's going to happen. Probably would require a double-header gripper with a SMD side and a PCB side.
  • Reckless
    104
    • May 9, 2023 at 7:15 PM
    correct for smd components and pcb assemblies. Mainly pcb assemblies 10x15mm and bigger. I prefer something like vacuum as fingers may not be as easy to grab odd shapes
  • Reckless
    104
    • May 9, 2023 at 7:17 PM
    Quote from Motouser
    I think in terms of inches/lbs but use mm/g when working with pcb components.
