When display is set to Single, half of the screen is taken up by a group of buttons - NEW INSTRUCTION, EDIT COMMAND, ADD MOVE POINT, TOUCHUP POINT. Is there a way to remove this? It is no different than Single Wide. I like the look when display is set to Double Horizontal but wish I didn't have to scroll so much.
Remove Helper Section when Programming on TP
bradbbarnett -
April 4, 2023 at 2:48 PM -
kwakisaki
April 4, 2023 at 2:56 PM Approved the thread. -
Press Edit Command and then Exit Icon.
You must use the EXIT ICON option.
Wow, so simple. Thanks guys.
I also think this another "improvement" is absolutely useless.
If you want to disable this feature for good, go to the system variable $UI_CONFIG.$ICON_EDIT and set everything to FALSE. -
I couldn't agree more.
I wish Fanuc would look at the "request to Fanuc" post and give us some real improvements.
EXACTLY!
Yeah, like imagine how good the vision could be today if they didn't spend years making it work on the touchscreen. Every other vision system has gone blowing by.
They are spending so much time for a kid to be able to program a robot, they haven't made improvements they could have.
I made a program, put it in every New robot, and run it first thing
