KRC 2 Velocity of motion lines are not being updated in .dat file
  • deadlyrefuge
  • March 8, 2023 at 8:42 PM
  • deadlyrefuge
    23
    Hey guys, so I am training a new guy at our company on the use and programming of our Kuka KR16. Our controller is KRC2 and the system is running software version KSS 5.6.54. The problem we are facing is that the when we program the PTP and LIN motions with a velocity. The velocity that we have set in those motion lines is not updated into the .Dat file. I did notice this before with another program I had written but the program was large and I did not have time to troubleshoot. So I just lowered the global speed override to something that was applicable for the job I was doing. The program runs but the speeds are wrong and I can't change them. I have tried using the CHANGE softkey to change the velocity, but that doesn't work. I have tried changing them directly in the .dat and that does change them, but when I use CHANGE on the points in the .src file, it then changes the .dat speeds back to the standard settings for velocity. Which are 100% for PTP, and 2.0 m/s for LIN.
    Here is the .src file;
    DEF HVOF12X12_2( )
    INT N
    ;FOLD INI
      ;FOLD BASISTECH INI
        GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
        INTERRUPT ON 3
        BAS (#INITMOV,0 )
      ;ENDFOLD (BASISTECH INI)
      ;FOLD USER INI
        ;Make your modifications here
      ;ENDFOLD (USER INI)
    ;ENDFOLD (INI)
    ;;FOLD STARTPOS
    ;$BWDSTART = FALSE
    ;PDAT_ACT = PDEFAULT
    ;BAS(#PTP_DAT)
    ;FDAT_ACT = {TOOL_NO 3,BASE_NO 6,MPBP Square 4 #BASE}
    ;BAS(#FRAMES)
    ;;ENDFOLD
    $ADVANCE = 5
    ;FOLD ---- Quickly skip BCO ----
    PTP $AXIS_ACT
    ;ENDFOLD
    ;FOLD SET DEFAULT SPEED
    $VEL.CP=0.25
    BAS(#VEL_PTP,25)
    BAS(#TOOL,0)
    BAS(#BASE,0)
    ;ENDFOLD
    $ADVANCE = 5
    PTP $AXIS_ACT ; skip BCO quickly
    $APO.CPTP = 1.000
    $APO.CDIS = 1.000
    $VEL.CP = .5
    ;PROGRAM RUNS OFF OF BASE_DATA[8] WHICH IS A SCRATCH PAD
    BASE_DATA[4] = {FRAME: X 461.614,Y 1356.136,Z 705.276,A 90.588,B -24.077,C -0.240}
    ;Part 4
    FOR N=1 TO 2 STEP 1;LOOP CYCLE
    ;FOLD PTP P1 Vel=50 % PDAT1 Tool[3]:HVOF 8 Base[4]:MPBP Square 2;%{PE}%R 5.6.13,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:P1, 3:, 5:50, 7:PDAT1
    $BWDSTART=FALSE
    PDAT_ACT=PPDAT1
    FDAT_ACT=FP1
    BAS(#PTP_PARAMS,50)
    PTP XP1
    ;ENDFOLD
    ;FOLD LIN P2 Vel=0.1 m/s CPDAT1 Tool[3]:HVOF 8 Base[4]:MPBP Square 2;%{PE}%R 5.6.13,%MKUKATPBASIS,%CMOVE,%VLIN,%P 1:LIN, 2:P2, 3:, 5:0.1, 7:CPDAT1
    $BWDSTART=FALSE
    LDAT_ACT=LCPDAT1
    FDAT_ACT=FP2
    BAS(#CP_PARAMS,0.1)
    LIN XP2
    ;ENDFOLD
    ;FOLD LIN P3 Vel=0.1 m/s CPDAT2 Tool[3]:HVOF 8 Base[4]:MPBP Square 2;%{PE}%R 5.6.13,%MKUKATPBASIS,%CMOVE,%VLIN,%P 1:LIN, 2:P3, 3:, 5:0.1, 7:CPDAT2
    $BWDSTART=FALSE
    LDAT_ACT=LCPDAT2
    FDAT_ACT=FP3
    BAS(#CP_PARAMS,0.1)
    LIN XP3
    ;ENDFOLD
    BASE_DATA[4]=BASE_DATA[4]: {X 0,Y -4,Z 0,A 0,B 0,C 0}
    ENDFOR
    END
    And here is the .dat file;
    DEFDAT  HVOF12X12_2
    ;FOLD EXTERNAL DECLARATIONS;%{PE}%MKUKATPBASIS,%CEXT,%VCOMMON,%P
    ;FOLD BASISTECH EXT;%{PE}%MKUKATPBASIS,%CEXT,%VEXT,%P
    EXT  BAS (BAS_COMMAND  :IN,REAL  :IN )
    DECL INT SUCCESS
    ;ENDFOLD (BASISTECH EXT)
    ;FOLD TOUCHSENS EXT
    EXT  H70 (INT  :IN,SRCH_TYP_2  :OUT,E6POS  :IN,SRCH_TYP_3  :IN,SRCH_TYP_2  :IN,SRCH_TYP_2  :IN,SRCH_TYP_2  :IN,SRCH_TYP_2  :IN,SRCH_TYP_2  :IN,INT  :IN )
    ;ENDFOLD (TOUCHSENS EXT)
    ;FOLD USER EXT;%{E}%MKUKATPUSER,%CEXT,%VEXT,%P
    ;Make here your modifications
    ;ENDFOLD (USER EXT)
    ;ENDFOLD (EXTERNAL DECLARATIONS)
    DECL BASIS_SUGG_T LAST_BASIS={POINT1[] "P4                      ",POINT2[] "P4                      ",CP_PARAMS[] "CPDAT2                  ",PTP_PARAMS[] "PDAT2                   ",CONT[] "                        ",CP_VEL[] "0.1                     ",PTP_VEL[] "100                     ",SYNC_PARAMS[] "SYNCDAT                 ",SPL_NAME[] "S0                      "}
    DECL E6POS XP1={X -31.4395409,Y 291.871002,Z -6.14646387,A 131.494705,B 16.4710407,C -178.931305,S 2,T 35,E1 -0.000175781301,E2 -25.0029507,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP1={TOOL_NO 3,BASE_NO 4,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT1={VEL 100.0,ACC 50.0,APO_DIST 100.0}
    DECL E6POS XP2={X 339.304413,Y 291.883087,Z -3.75771403,A 131.496094,B 16.4709606,C -178.932404,S 2,T 35,E1 -0.000175781301,E2 -25.0029507,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP2={TOOL_NO 3,BASE_NO 4,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL LDAT LCPDAT1={VEL 2.0,ACC 50.0,APO_DIST 100.0,APO_FAC 50.0,ORI_TYP #VAR,CIRC_TYP #BASE,JERK_FAC 50.0,EXAX_IGN 0}
    DECL E6POS XP3={X -31.4395409,Y 291.871002,Z -6.14646387,A 131.494705,B 16.4710407,C -178.931305,S 2,T 35,E1 -0.000175781301,E2 -25.0029507,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP3={TOOL_NO 3,BASE_NO 4,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL LDAT LCPDAT2={VEL 2.0,ACC 50.0,APO_DIST 100.0,APO_FAC 50.0,ORI_TYP #VAR,CIRC_TYP #BASE,JERK_FAC 50.0,EXAX_IGN 0}
    DECL E6POS XP4={X -20.6515598,Y -1076.73401,Z -0.722322822,A 132.113205,B 16.1825409,C -178.4207,S 2,T 11,E1 -0.000175781301,E2 -25.0032997,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP4={TOOL_NO 3,BASE_NO 3,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT2={VEL 100.0,ACC 50.0,APO_DIST 100.0}
    ENDDAT
    As well, we have tried doing all this in multiple user groups; programmer, expert, and administrator. Nothing seems to work.
    What am I missing?
  • Go to Best Answer
  • Lemster68 March 8, 2023 at 8:48 PM
    Approved the thread.
  • SkyeFire
    1,044
    9,391
    • March 8, 2023 at 10:41 PM
    Quote from deadlyrefuge
    "Doesn't work" how? Details matter. Does the Change button just not do anything? Does the ILF open up? If/when you try to make the change and hit OK, do any messages show?
    Are these ILF points created using the Move menu option? Or was this program copied into the robot from somewhere else?
    Regardless, the PDAT.VEL and LCPDAT.VEL values in the .DAT file are irrelevant for ILF motions. The BAS call inside the Fold is what matters:
    $BWDSTART=FALSE
    LDAT_ACT=LCPDAT2
    FDAT_ACT=FP3
    BAS(#CP_PARAMS,0.1)
    LIN XP3
    ;ENDFOLD
    The red value you enter in the VEL box of the ILF is (or should be) written into the (also red) value in the BAS call. And that value is what normally sets the motion velocity, not LCPDAT2.VEL
    First thing to check: if you use the Change button, does the value in the BAS call change? If not, something may be broken in your ILF, which is... not good. Second, if the BAS call value does change, but the robot still moves at max speed, that suggests something has been modified in BAS.SRC.
    panic mode
    1,268
    13,041
    • March 8, 2023 at 11:52 PM
    just to be precise - what was shared is actually content of the files, and not the actual files. and the shown content is also only partial. actual files would have more info - they would show header before DEF line as well as file attributes. if the files attributes are not correct (read only), it is still possible to open or select the module but not edit it.
    my suggestion is to always describe problem in such a way that others could reproduce it. in this case that would include user level, operating mode, how the module is accessed exactly (opened or selected), list any messages before and after attempt to edit, show operating mode, etc. i know that it is hard to think everything that others may ask for so perhaps a video clip or few pictures could help.
  • deadlyrefuge
    23
    • March 9, 2023 at 12:35 AM
    These are files taken directly from our controller. These files run. Every part of the file was copied and added into this forum post.
    As for the questions about "not working" as in I can change the values in the program, but that doesn't change the values in the .dat file. The motion files are created using the move menu options.
    As for user level. I have specified that. It was in t1 operating mode. Modules were both opened and edited, as well as then we selected them and edited. Both times produced the same results. And no messages before or after. There were no errors. The only reason I noticed the difference was because I went into the .DAT file and noticed the velocity was different than what we had in the .src file.
    Though at the end of the day, we tried running it one more time and it seemed like the program was accurate for speed. Kinda hard to tell other than measuring it out in a linear straight motion though.
    But if it is accurate. Why is the .dat file not being updated with the velocity speeds?
  • deadlyrefuge
    23
    • March 9, 2023 at 12:36 AM
    We also of course ran the program in auto mode. In case you're wondering
    panic mode
    1,268
    13,041
    • March 9, 2023 at 2:38 AM
    those are inline form motions. velocity is set in the SRC file and some of values in DAT file are simply not necessary.
    if you look inside inline form of any motion, you will see that programmed speed is set just before actual motion (PTP or LIN) by calls to BAS module. to see what is going on you need to check BAS.SRC.
    BAS(#PTP_PARAMS,50) ; sets PTP velocity to 50%
    inside BAS.SRC you should see something like:
    so when using #PTP_PARAMS, internally there are three subroutines that get called and the last one is VEL_PTP(50) that sets velocity to 50% (REAL_PAR gets value from your program)
    BAS(#CP_PARAMS,0.1) ; sets CP velocity to 0.1m/s (LIN and CIRC)
    like above here the last subroutine is VEL_CP(0.1)
    after that instruction pointer returns to your SRC file and executes next line of program which is motion... velocity values in DAT file are ignored and it turns out - in your version of KSS, editor does not bother to update them in the DAT file
  • deadlyrefuge
    23
    • March 9, 2023 at 2:41 AM
    Ahhhh I see now. Thanks panic mode for your help!
    panic mode
    1,268
    13,041
    • March 9, 2023 at 2:49 AM
    you are welcome
    panic mode
    1,268
    13,041
    • March 9, 2023 at 2:58 AM
    btw as far as i can tell this is not common. if my memory is any good, editors usually do update things in the DAT file too. that is at least the case in everything i recently checked out. but there are some version differences and when replying i used screenshots from BAS.SRC that is similar vintage as yours. this is just to show that details do matter. i am not telling forum members to share details because i am trying to show of or intimidate. there are simply too many things to think of and very often things come down to something that was misunderstood. when i read (skimmed) your first post, it sounded like inline form editor was crashing or maybe failing to update value or that program was possibly executing at different velocity than programmed. i did not realize that program was ok but the concern in question was simply the non-changing value in DAT file (and that is not expected for me as well )
  • deadlyrefuge
    23
    • March 9, 2023 at 3:10 AM
    Ahhh I see, ya we were just concerned because I usually check the dat file to double check my values are set and to modify any external axis numbers, etc. And that's when I noticed the velocity numbers were completely different. I should have mentioned when I first posted that the program seems to run properly. Sorry about that.
  • hermann
    405
    2,597
    • March 9, 2023 at 5:48 AM
    • Best Answer
    • #11
    I also would say, shame on Kuka, that they aren't able to delete that velocity value in the Dat file. This obsolete value confuses not only you, but many many other programmers.
  • Fubini
    272
    1,873
    • March 9, 2023 at 7:28 AM
    • #12
    Also shame on all KUKA customers that want to have backward compatibility for way back :winking_face_with_tongue: . That's the only reason why its not removed. Actually removing it would be quite simple for KUKA. but you would not be able to easily port from controller A where dat-file VEL exists in the struct to controller B where its already removed in the structure declarations. In the past when something similar was done the cry out of important customers was so big that KUKA learned to avoid to get himself in such situations.
    Another strong argument to not change stuff like this is the following:
    The structures you are referring to in the dat-file are intended to be used together with inline forms and therefore addresses people who do not care how internally inline forms are working because they use the HMI GUI menues anyway for their programming as intended by KUKA for this type of users. So they do not need to understand whats going on behind the scenes to get their job done. As said before the robot behaves exactly as expected when using inline forms. The confusion only sets in for the small amount of users that want to use inline forms but also want to understand the behind the scenes. So basically "experts" of some kind. If you would remove the VEL structure you would make the "problem" a concern not only for a few "experts" but also for the vast majority of GUI programmers who do not bother about this stuff as well. And then these would also have to deal with the above mentioned compatibility issues.
    Fubini
  • hermann
    405
    2,597
    • March 9, 2023 at 12:50 PM
    • #13
    Yes, of course the backwards compatibility, but somewhere there must have been a break of it. As the structure is existing, and so you can think that it was used in former days. Then someone decided to do it different, that was the mistake. But that's history, we have to deal with it, and so there will be some more Kuka users that will fall into that trap :smiling_face_with_sunglasses: .
  • motion
  • velocity
  • KSS
  • LIN
  • kss5.6.54
  • ptp
  • .dat
  • .src
