Load TP Program from Memory Card automatically using Karel
  • darkknight1499
  • October 7, 2022 at 12:36 PM
  • darkknight1499
    30
    I tried writing the karel code but it didn't compile and kept giving errors.
    Can someone help me how to write the proper karel code for this.
    Images
      • 235.85 kB
      • 1,920 × 1,080
      • 49
  • hermann
    404
    2,595
    • October 7, 2022 at 2:13 PM
    You should provide your faulty code, so someone can correct it. That's easier than writing whole code from scratch.
  • darkknight1499
    30
    • October 7, 2022 at 6:03 PM
    I've tried the following code snippet but it didn't work.
    Please guide me to correct the code.
    EXT_LOAD(list_name)
    [in] list_name : STRING
    PROGRAM EXT_LOAD
    EXT_LOAD(list_name)
    END EXT_LOAD
  • hermann
    404
    2,595
    • October 8, 2022 at 7:16 AM
    PROGRAM EXT_LOAD1
    EXT_LOAD('MC:\list')
    END EXT_LOAD1
    This line with [in] is some kind of Syntax describing. Always use the part from Example. May be the slash has to be a backslash.
    As far as I understand the doc, there must exist a file on MC: with name 'list' that contains the names of TP programs that will be loaded.
    Think it's not a good idea to name the own procedure the same name of the external routine.
    Edit: forgotten ':' after MC. And changed / by \
  • DS186
    198
    1,049
    • October 8, 2022 at 9:08 AM
    As hermann already suggested, use :\ instead of / in your code. This is often a problem in FANUC manuals that the backslash is not correctly translated.
  • darkknight1499
    30
    • December 8, 2022 at 9:41 AM
    hermann and DS186 , I still haven't been able to create the karel code to load the tp program. I even went to fanuc engineers for help but nothing worked out.
    I'm still getting errors while creating the karel file.
    I've attached the image of the error I'm getting and the code I've written.
    Images
      • 547.29 kB
      • 1,920 × 1,081
      • 27
  • darkknight1499
    30
    • December 8, 2022 at 9:50 AM
    The referance for the code is available in manual (B-83274EN/02) "System Design Tool Operator's Manual" Chapter 5.
    I'm attaching the screenshot so you guys can have a look at it and see if I'm missing any thing or doing something wrong.
    Images
      • 267.51 kB
      • 1,920 × 983
      • 20
  • DS186
    198
    1,049
    • December 8, 2022 at 9:58 AM
    Quote from darkknight1499
    Read the message from the KTRANS window. Your code is missing a BEGIN statement after the line PROGRAM EXT_LOAD1.
  • darkknight1499
    30
    • December 8, 2022 at 10:06 AM
    Quote from DS186
    I've tried that but then it gives another error. And the manual hasn't specified to use BEGIN in that code.
    Images
      • 434.19 kB
      • 1,600 × 1,200
      • 18
  • DS186
    198
    1,049
    • December 8, 2022 at 10:16 AM
    PROGRAM EXT_LOAD1
    BEGIN
    EXT_LOAD('MC:\LIST')
    END EXT_LOAD1
  • darkknight1499
    30
    • December 8, 2022 at 10:26 AM
    • #11
    Still the same error.
    Images
      • 399.57 kB
      • 1,600 × 1,200
      • 18
  • Nation
    Typical Robot Error
    523
    1,901
    • December 8, 2022 at 4:33 PM
    • #12
    EXT_LOAD isn't a karel built in. I would use LOAD. Also, you will need the file extension if you want to load something ('MC:\list.tp' for example).
  • darkknight1499
    30
    • December 8, 2022 at 4:37 PM
    • #13
    Quote from Nation
    I'm attaching the example code fanuc have given in manual.
    The file list is supposed to be made in a .DT file.
    Images
      • 267.43 kB
      • 1,920 × 983
      • 23
  • TitusLepic
    112
    442
    • December 8, 2022 at 5:12 PM
    • #14
    You're missing the "CALL"
  • TitusLepic
    112
    442
    • December 8, 2022 at 5:30 PM
    • #15
    Also, here's a related thread you might find helpful (or confusing): RE: Karel Program
  • Nation
    Typical Robot Error
    523
    1,901
    • December 8, 2022 at 7:02 PM
    • #16
    That is a call from a teach pendant program to a compiled Karel program. While you can call other Karel programs from Karel, I don't think that is the intention here.
  • hermann
    404
    2,595
    • December 9, 2022 at 11:09 AM
    • #17
    RTFM. You can call those System Design Tool functions only from TP programs, not from Karel programs. May be it is possible, and I haven't found it, but all examples in manual are with TP programs:
    Addendum:
    You can see the source code of exactly the function of EXT_LOAD in the 'KAREL Function OPERATOR'S MANUAL' in the chapter "4.4.2 Save,Delete, Load the Program Based on the List."
    From there on you can build your own karel procedure according to your needs.
  • R47
    109
    • December 9, 2022 at 3:02 PM
    • #18
    hi Darkknight1944,
    This should work with Karel try:
    LOAD('UD1:example.TP',1,status)
    change "UD1" to your path "MD" or "UT1"...
  • darkknight1499
    30
    • December 10, 2022 at 1:18 PM
    • #19
    Thanks hermann now it is clear.
  • darkknight1499
    30
    • December 10, 2022 at 1:27 PM
    • #20
    Quote from R47
    hi Darkknight1944,
    Hii R47, I tried your method it worked very straight forward for me.👍🏻
    I'm writing the whole code below so it is simpler if anybody look for it in future.
    PROGRAM Auto_Load
    BEGIN
    LOAD('MC:FILE.TP', 1, 1)
    END Auto_Load
  • Rj3ib
  • TP programming
  • Karel programming
  • load program
