krc4 communication with "Jetson AGX xavier(Linux)"
  • Djonatan Meinicke
  • May 25, 2022 at 10:29 PM
  • Djonatan Meinicke
    5
    Hy!!
    I want communication my krc4 with a Linux, send/recive bits from the Kuka and send/recive bits from Linux.
    what is the best form I can do this, what Protocol?
    Anyone has been do this?
    thanks!
  • panic mode
    1,262
    13,030
    • May 26, 2022 at 4:19 AM
    the best would be to define application requirements and available communication options of the specific products in use (both Jetson module and the KRC).
    SkyeFire
    1,038
    9,373
    • May 26, 2022 at 3:22 PM
    KRC4s support EtherCat natively, but with limitations. There are KUKA optional software packages to support ProfiNet, Ethernet/IP, and simple TCP/IP string exchange (basically, Telnet). With added hardware, older FieldBusses like ProfiBus, DeviceNet, InterBus (also ModBus?) can be supported.
    I believe there is a software option to add OPC/UA.
  • Nicolas Molina Methfessel
    15
    • July 18, 2022 at 12:57 AM
    On the Jetson devices running Linux you can install Codesys runtime for Linux Codesys control for linux sl bundle. This gives you almost any communication on the Jetson side (or even a raspberry Pi) and you can program it like a PLC. You can pair that with any communication on the KRC side
