Idea for slowing down robot, when PLC sends trigger signal over ProfiNet.
  • ChristianLiinHansen
  • May 12, 2022 at 9:37 PM
    37
    Hi out there.
    I want to run two interrupts, triggered over ProfiNet at $IN[401]. When signals go TRUE, the robot should ramp down in speed, wherever it is, and stop within like say 2-3 sec. And when signal is FALSE, the robot should ramp up again. My idea was as followed in this test program below, where I declare the interrupts as below:
       INTERRUPT DECL 30 WHEN $IN[401] == TRUE DO ISR_SlowSpeedTestTrue()
       INTERRUPT DECL 31 WHEN $IN[401] == FALSE DO ISR_SlowSpeedTestFalse()
    Full test program:
    Code: SlowSpeedTest.src
    &ACCESS RVP
    &REL 16
    &PARAM EDITMASK = *
    &PARAM TEMPLATE = C:\KRC\Roboter\Template\vorgabe
    &PARAM DISKPATH = KRC:\R1\Program\HelperFunctions
    DEF SlowSpeedTest( )
       $ADVANCE = 1
       LOOP
       INTERRUPT ON 30 ; Enable the interrupt
       INTERRUPT ON 31 ; Enable the interrupt
    ;FOLD SPTP P1 CONT Vel=100 % PDAT1 Tool[1]:ForkCenterOfBoxCAD Base[5]:PalletAligned ;%{PE}
    ;FOLD Parameters ;%{h}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=P1; Kuka.BlendingEnabled=True; Kuka.MoveDataPtpName=PDAT1; Kuka.VelocityPtp=100; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
    ;ENDFOLD
    SPTP XP1 WITH $VEL_AXIS[1] = SVEL_JOINT(100.0), $TOOL = STOOL2(FP1), $BASE = SBASE(FP1.BASE_NO), $IPO_MODE = SIPO_MODE(FP1.IPO_FRAME), $LOAD = SLOAD(FP1.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT1), $APO = SAPO_PTP(PPDAT1), $GEAR_JERK[1] = SGEAR_JERK(PPDAT1), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0) C_Spl
    ;ENDFOLD
    ;FOLD SPTP P2 CONT Vel=100 % PDAT2 Tool[1]:ForkCenterOfBoxCAD Base[5]:PalletAligned ;%{PE}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=P2; Kuka.BlendingEnabled=True; Kuka.MoveDataPtpName=PDAT2; Kuka.VelocityPtp=100; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
    ;ENDFOLD
    SPTP XP2 WITH $VEL_AXIS[1] = SVEL_JOINT(100.0), $TOOL = STOOL2(FP2), $BASE = SBASE(FP2.BASE_NO), $IPO_MODE = SIPO_MODE(FP2.IPO_FRAME), $LOAD = SLOAD(FP2.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT2), $APO = SAPO_PTP(PPDAT2), $GEAR_JERK[1] = SGEAR_JERK(PPDAT2), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0) C_Spl
    ;ENDFOLD
    ;FOLD SPTP P3 CONT Vel=100 % PDAT3 Tool[1]:ForkCenterOfBoxCAD Base[5]:PalletAligned ;%{PE}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=P3; Kuka.BlendingEnabled=True; Kuka.MoveDataPtpName=PDAT3; Kuka.VelocityPtp=100; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
    ;ENDFOLD
    SPTP XP3 WITH $VEL_AXIS[1] = SVEL_JOINT(100.0), $TOOL = STOOL2(FP3), $BASE = SBASE(FP3.BASE_NO), $IPO_MODE = SIPO_MODE(FP3.IPO_FRAME), $LOAD = SLOAD(FP3.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT3), $APO = SAPO_PTP(PPDAT3), $GEAR_JERK[1] = SGEAR_JERK(PPDAT3), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0) C_Spl
    ;ENDFOLD
    ;FOLD SPTP P4 CONT Vel=100 % PDAT4 Tool[1]:ForkCenterOfBoxCAD Base[5]:PalletAligned ;%{PE}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=P4; Kuka.BlendingEnabled=True; Kuka.MoveDataPtpName=PDAT4; Kuka.VelocityPtp=100; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
    ;ENDFOLD
    SPTP XP4 WITH $VEL_AXIS[1] = SVEL_JOINT(100.0), $TOOL = STOOL2(FP4), $BASE = SBASE(FP4.BASE_NO), $IPO_MODE = SIPO_MODE(FP4.IPO_FRAME), $LOAD = SLOAD(FP4.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT4), $APO = SAPO_PTP(PPDAT4), $GEAR_JERK[1] = SGEAR_JERK(PPDAT4), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0) C_Spl
    ;ENDFOLD
       ENDLOOP
    END
    ISR for Slowing down the robot.
    Code: ISR_SlowSpeedTestTrue.src
    &ACCESS RV1
    DEF ISR_SlowSpeedTestTrue()
    DECL INT count
    INTERRUPT OFF 30
    ; Ramp down
    ;FOR count = 100 TO 0 STEP 10
    ;$OV_PRO = count
    ;WAIT SEC 0.1
    ;ENDFOR
    ;Somehow the for loop did not work, but I will figure this out later... Perhaps because I cant declare INT in an interrupt?
    $OV_PRO = 90
    WAIT SEC 0.1
    $OV_PRO = 80
    WAIT SEC 0.1
    $OV_PRO = 70
    WAIT SEC 0.1
    $OV_PRO = 60
    WAIT SEC 0.1
    $OV_PRO = 50
    WAIT SEC 0.1
    $OV_PRO = 40
    WAIT SEC 0.1
    $OV_PRO = 30
    WAIT SEC 0.1
    $OV_PRO = 20
    WAIT SEC 0.1
    $OV_PRO = 10
    WAIT SEC 0.1
    $OV_PRO = 0
    WAIT SEC 0.1
    END
    ISR for speeding up the robot again...
    Code: ISR_SlowSpeedTestFalse.src
    &ACCESS RV1
    DEF ISR_SlowSpeedTestFalse()
    DECL INT count
    INTERRUPT OFF 31
    ; Ramp up
    ;FOR count = 0 TO 100 STEP 10
    ;$OV_PRO = count
    ;WAIT SEC 0.1
    ;ENDFOR
    $OV_PRO = 10
    WAIT SEC 0.1
    $OV_PRO = 20
    WAIT SEC 0.1
    $OV_PRO = 30
    WAIT SEC 0.1
    $OV_PRO = 40
    WAIT SEC 0.1
    $OV_PRO = 50
    WAIT SEC 0.1
    $OV_PRO = 60
    WAIT SEC 0.1
    $OV_PRO = 70
    WAIT SEC 0.1
    $OV_PRO = 80
    WAIT SEC 0.1
    $OV_PRO = 90
    WAIT SEC 0.1
    $OV_PRO = 100
    WAIT SEC 0.1
    END
    I was looking into the manual and was thinking, that I should be able to override the acceleration, and I was trying to set
    $ACC, $ACC_OV etc, but it complained when I e.g. set
    $ACC.CP = 1.
    So therefore I went back to the OV_PRO version, and "manually" ramping down using decrementing the value with an wait statement. I think this is a bit ugly, so what is the best practice to do this?
    Thanks in advance...
    My current system contains the following information:
    • Robot: KUKA KR50 R2100
    • Controller: KR C5 dualcabinet
    • KSS 8.7.2 HF3
    • HMI version: 8.7 B394
    • Kernel system version: KS V8.7.53394
    • WorkVisual V6.0.24_Build1632
  • DS186
    200
    1,075
    • May 12, 2022 at 10:11 PM
    I would either use an interrupt with a Brake command or the functions ROB_STOP() and ROB_STOP_RELEASE(). Check the manual for details and examples.
  • panic mode
    1,295
    13,130
    • May 12, 2022 at 10:33 PM
    when counting down step need to be negative. so change 10 to -10 for the step value and it should be ok.
    still... i would not place loop and delays inside an interrupt. this is is better done in submit.
  • SkyeFire
    1,060
    9,456
    • May 13, 2022 at 2:22 PM
    I agree with Panic. Generally, you want to get in and out of an ISR as quickly as possible, except in situations where you're actually stopping the robot process (IR_STOPM comes to mind). Ramping $OV_PRO in the SPS is probably the better way to go, here.
    Alternatively, using BRAKE or ROB_STOP in your ISR should achieve the same result, unless you really want a slow ramp-down.
  • hermann
    411
    2,621
    • May 13, 2022 at 7:38 PM
    One more possibility is to create a second interrupt triggered by a timer flag. In the existing interrupt set the timer to -100, this should trigger the second, in that interrupt set the override and reset the timer again.
  • panic mode
    1,295
    13,130
    • May 13, 2022 at 7:54 PM
    i was reluctant to suggest that after seeing what has found its way into ISR :grinning_face_with_smiling_eyes:
    37
    • May 13, 2022 at 10:18 PM
    Quote from SkyeFire
    Hi SkyeFire .
    So the tool of the robot will carry a relative large load, so yes I really want a slow ramp-down of minimum 3 sec or something. Not stop immediately. but spend minimum like 3-5 sec to ramp slowly down...
    • KSS 8.7.2 HF3
  • SkyeFire
    1,060
    9,456
    • May 16, 2022 at 2:12 PM
    3-5sec decel is meters of motion, unless your robot is moving very slowly, in which case you hardly need such a long decel ramp. How did you come up with that number? I honestly can't see any application that would need such a long decel ramp, aside perhaps from carrying an open-topped bucket of water and not wanting to spill a drop.
    As long as the robot has good $LOAD data, issuing a basic BRAKE command in the ISR should give you a path-maintaining stop that's not very violent, but requires much less time that 3-5sec. Have you tried that approach?
