  4. ABB Robot Forum
Baseware 2.1 for m94a irb 6400
  • 851dave
  • May 2, 2022 at 10:25 AM
  • 851dave
    45
    good morning
    Does anyone have a copy of 3hab 2340-1 for an m94a irb 6400.i have 3hab 2333 but this doesnt prompt for the motor type,in this case elmo
    Regards Dave
  • Skooter
    167
    2,001
    • May 3, 2022 at 3:08 AM
    3HAB2333-1 RW2.1 with 3 disks.
    During/after disk 3, it should ask to select the type of software load - either Standard or Service - select Standard.
    It will then ask for the Teach Pendant Text disk (3HAB2356-1 for RW2.1) and after it starts loading, it then asks to select language, IRB type, mounting.
    It then asks for the IRB disk (3HAB2340-1 for RW2.1 IRB6400 M94A) and load the appropriate files for the IRB type previously selected.
    After loading the IRB info, it will then ask if there are any option disks. I suggest answering NO until you get the motion part working.
  • 851dave
    45
    • May 4, 2022 at 5:52 PM
    hi skooter
    the irb disk that came with my software is 3hac 2342, there is no 2340 supplied,also
    i have tried service and standard but neither way it prompts me for the motor type
    i am wondering if i need an earlier version of software.
  • Skooter
    167
    2,001
    • May 5, 2022 at 1:18 AM
    3HAB2342 is the M96 2.1 IRB6400 disk so it will only load the M96 arm, that's why it doesn't prompt.
    BW2.1 is a great version, just need a disk set with the M94A 2.1 IRB disk (3HAB2340).
    It can run 2.0 which has just the one IRB disk and will give you the prompt.
    BW3.0 also requires a M94A IRB 3.0 disk
Similar Threads
  • Strange movement after baseware installed m94a
    • 851dave
    • April 19, 2022 at 11:05 AM
    • ABB Robot Forum
  • I need config for abb irb 6400/f/2.4-150e s4
    • wowa_wa
    • February 10, 2022 at 8:42 PM
    • ABB Robot Forum
