i need help with this problem?
Emergency stop inoperative
Zago -
April 14, 2022 at 8:31 AM -
The problem is most likely the missing connection. Whats the history? Tried a different SmartPad? ...
ThreadREAD FIRST...
how to post correctly:
1. be a good citizen and follow common sense. this includes no sharing or asking for copyrighted material. such posts will get you banned (because we don't want Kuka legal team stepping in and request ban on all manuals). an example of something that will get you in trouble is any material from Kuka College.
1.5 make SURE to post in the right forum section (manuals in manuals section, IIWA and Sunrise topics in IIWA section). see attached example for IIWA... sigh..
Please…panic modeJune 5, 2016 at 4:30 PM Fubini
That smartpad has not booted up correctly
how can i fix this error
ThreadREAD FIRST...
there is only one smartpad so i can't try it
If you do not provide any detail what happened I can only advise to reinstall everything. Procedures how to do this can be found in the handbooks of your machine whatever that is.
Did you connect a monitor to check if KSS is up and running?
Fubini
SmartPad essentially only hosts a small Windows CE that tries to connect to the real controller inside the cabinet using the rdp protocol. Either side of the rdp connection could be the culprit.
Fubini
This is first thing to do having this fault.
