Office Lite Inadequate robot position
  • RainerFord
  • December 14, 2021 at 8:06 AM
  • RainerFord
    27
    Hello
    We purchased KR40 PA and it is on the way. So I don't have the real robot right now, but I want to make some offline programming with Office Lite.
    I made the new WoV project with the right controller,KSS version and robot. But when I deploy it on the OL, the virtual robot starts with the inadequate position as you can see on screenshot. The problem is I cant move it to the right position even with turned off software limits for all axis because of 5th, that seems to be flipped...
    What am I doing wrong? I don't believe, that OL don't have the feature to simulate the robot when you don't have the backup from real one...
    Images
      • 44.36 kB
      • 525 × 726
      • 15
    Edited 2 times, last by RainerFord (December 14, 2021 at 8:59 AM).
  • Fubini
    284
    1,906
    • December 14, 2021 at 9:03 AM
    • Best Answer
    Easiest way to fix this is to remaster the robot inside OL. This should switch the current position to a valid one.
    Fubini
  • panic mode
    1,300
    13,143
    • December 14, 2021 at 2:48 PM
    ...or just jog axes to a normal range.
    either way you will see this every time you start OL. if this is too much of a annoyance, consider opening soft limits to include initial position.
  • MOM
    176
    7
    1,424
    • December 14, 2021 at 4:58 PM
    The problem should be axis 2 and axis 3
  • MOM
    176
    7
    1,424
    • December 14, 2021 at 8:35 PM
    just using the demo version of robodk:
    comparing it with your image from post #1 there is little difference
    There also might be a (known) problem with OL
    Running OL the first time using a specific robot you always going to have the problem you are having right now (unless you screwed up the first place) .
    In order to solve the problem you need to move all the axes (a2 and and a3) into the allowed area, make cold start with reading files and the problem should be solved.
    PA robots only have 4 axes , one axis is set to zero (normally a4) and axis 5 depends on the settings of axis 2 and axis 3 (you normally can not change a5).
