  4. Nachi Robots
Nachi Robot Offset Move
  • kevilay
  • October 21, 2021 at 2:44 PM
  • kevilay
    134
    Hey guys,
    I am workin with my first nachi robot and am looking to write an offset program. Normally when programming robots I will read in my current position, then apply either apply a set z height that I know is clear to the current position or apply a static z offset. Then go to the same position that it was left at (random position in travel) then apply the offset and it will move up to a safe height, then from there it can go home. What does this look like in nachi? I am currently attempting to do this using XYZ shift FN58 but even with it all being linear moves when I apply the shift the robot will move up but it doesnt maintain the pitch/roll It moves the TCP straight up, but also rolls it quite a bit. I have tried this using world and TCP frames. Please let me know if you have any suggestions.
    Thanks,
    Kevin
  • bsrr
    148
    • October 22, 2021 at 2:46 AM
    Example to Home the robot as below
    DIM Position[2] As POSITION 'FN801-DEFINE Variable Position
    MOVEX A=1,AC=0,SM=0,M1J,P,P*,R=20.0,H=2,MS 'Move to Current position
    GETPOS 0,1,Position[1],0,1 ' USE FN 822 -Get Current Machine cordinate position
    OPEPOS 0,Position[1],V1!,0,0' USE FN 826- Extract X,Y,Z,Roll,pitch,yaw into real variables V1 to V6
    Current position of (Z) available in V3!.You can then use IF statements to compare V3! and then MOVE robot safely to Home
  • kevilay
    134
    • October 25, 2021 at 2:31 PM
    Quote from bsrr
    I am a little confused by this. I am not exactly sure what the movex does. If in my case I would try to move to a z of a fixed 500 how would I do the final move with the current position applied? I think I need 1 more line but am struggling with getting it working.
  • bsrr
    148
    • October 26, 2021 at 12:13 AM
    USE 1
    MOVEX A=1,AC=0,SM=0,M1J,P,P*,R=20.0,H=1,MS
    INH
    GETPOS 0,1,Position[1],1,1
    V3! = V3!+500
    OPEPOS 0,Position[1],V1!,0,1
    POS2POSE 0,Position[1],1,1,P1
    MOVEX A=1,AC=0,SM=0,M1J,L,P1,R=50.0,H=1,MS
    END
    Above ASCII code need to be compiled
    MOVEX and Pose file details are available in the Robot Language Manual.
  • kevilay
    134
    • October 27, 2021 at 2:13 PM
    Thank you for the help. This is now working.
  • dkeranen
    • January 13, 2023 at 6:49 PM
    Hi BSRR,
    Thanks for the code above. I appreciate you taking the time to help out.
    I don't have the manual that describes those functions in your sample code above. Would you be able to list the variables and what they do for the functions below? Also is there a manual that lists and describes all of these functions. I have the handling and robot language manuals.
    DIM
    GETPOS
    OPEPOS
    POS2POSE
  • bsrr
    148
    • January 14, 2023 at 2:39 AM
    Quote from dkeranen
    DIM
    GETPOS
    OPEPOS
    POS2POSE
    The above Function descriptions are available in the Command reference manual TFDEN-092
  • CharlesWar
    • February 28, 2023 at 4:55 PM
    I Find this
    FN801 - DIM
    FN645 - MOVEX
    FN310 - INH
    FN822 - GETPOS
    FN826 - OPEPOS
    FN638 - ADD REAL VARIABLE
    FN809 - POS2POSE
    You can review the manual in the Teach of the robot
    I will try modify with it next week.
    regards
Similar Threads
  • Robot Issue: Kuka KR 150.2
    • technician820
    • March 29, 2019 at 9:47 PM
    • KUKA Robot Forum
  • Frame Transforms
    • atomic_robo
    • June 28, 2018 at 6:55 PM
    • KUKA Robot Forum
  • nachi
  • linear motion
