Hi mine relay number is starting from 20070 by profinet how to map this and how to use this in program for waiting for iPhone ND making op high please
Profinet i/o issue
Thejesh -
April 22, 2021 at 10:46 AM -
How many byte you define for inputs in your setting?
Usually, from 20060 to 20067 are for communication status and you can use from 20070 to any byte you define in setting.
You can use bit by bit from starting address in you job.
Please explain more about your application.
I am using 8 bytes and I checked in general inputs and output the inputs are from IN#0033(00050) whether I have to use IN#0033 OR 00050 in my job
In your job you must use IN#xxxx address,
For example you will use WAIT instruction,
You write :
WAIT IN#(0033) =ON
