I desperatly need help.
We have 2 CS8 on a remote site.
There is a VPN set up for the machines.
I can PING the ProfiNet IP address x.x.x.50 and x.x.x.60.
But I cant PING the J205 port address x.x.x.51 and x.x.x61.
Both J205 and Profinet are set up with same SUBNET (255.255.255.0) and Gateway. (x.x.x.254)
When i was onsite (before the VPN was setup) i could connect, via a switch at the machines and a switch on the network outside the machine.
I talked to Staubli hotline and was told that if IP, subnet and gateway is setup then there should be no issue connecting via VPN.
Can someone shed some light on my issue ... I feel I have tried everything.
