KUKA KRC1 NOT MOVING AXIS A4, A5 and A6
  • legityme
  • April 15, 2021 at 2:16 PM
  • legityme
    85
    Hello guys!
    I’m testing a KUKA KRC1 cabinet with a KR 200-4 robot but the AXIS A4, A5 and A6 do not move. A1, A2 and A3 are fine. When I try to move the last 3 axis, the following message appears: Ackn: Motor blocked A4... Drives contractor off. Is it a failure from the PM6? What should I look on the PM6 to see if it is defective?
    Thank you!
  • panic mode
    1,295
    13,130
    • April 15, 2021 at 2:17 PM
    READ FIRST...
  • legityme
    85
    • April 15, 2021 at 2:22 PM
    It’s KSS V2.3.34 SP08
  • panic mode
    1,295
    13,130
    • April 15, 2021 at 2:27 PM
    please post screenshot of the messages. list of messages, message details (like msg number), order of messages matters, etc.
  • panic mode
    1,295
    13,130
    • April 15, 2021 at 2:37 PM
    i guess it is this one
  • legityme
    85
    • April 15, 2021 at 5:31 PM
    Thank for your answer panic mode, a photo of the errors is attached. The same two messages appear when I try to move A4, A5 and A6
    Images
      • 70.38 kB
      • 864 × 1,152
      • 17
  • panic mode
    1,295
    13,130
    • April 15, 2021 at 6:05 PM
    you should follow advice...
    it was already suggested to read READ FIRST...
    and reason it was suggested is not just to make you read something but to follow it..
    it explains how the screenshot should look like. it should be full screen, not part of it. it should be processed (scaled, rotated etc.) by YOU....
    it also tells to read all messages and observe timestamps as order matters and many messages are result of others, hence you need to find the root, where it all started...
    judging by the scrollbar in the lower right corner, there are more (earlier) messages that you did not share...
    and yes, i see that robot has unmastered axes... that is always a red flag. but it is not PM6... if that was the problem, you would not be able to move any axis.
Similar Threads
  • KR150L130 & VKRC2
    • javaman
    • July 22, 2019 at 11:26 PM
    • KUKA Robot Forum
  • kr210 vibrate when jogging the axes
    • ROBOT_LIU
    • December 24, 2018 at 12:40 PM
    • KUKA Robot Forum
  • Need proper mada 2001 kr200sp/2, 2003 krc2
    • switch
    • June 1, 2018 at 5:54 PM
    • KUKA Robot Forum
  • KUKA KRC1
