Fanuc Webserver through VPN
  • RoboRuben
  • January 6, 2021 at 3:44 PM
  • RoboRuben
    We have an installation with a Fanuc robot. We would like to use a VPN to connect with the webserver. I'm able to connect with my pc with the robot through a Siemens switch. But if I try this with a remote connect vpn-module (Siemens Scalance M) the ECHO function of the robot fails to connect.
    So i'm sure that I can connect with my pc to that robot, but I'm not able to do it wireless.
    Can anyone help me?
  • HawkME
    568
    3,268
    • January 6, 2021 at 4:00 PM
    What does it do when you try to connect?
    Are there any error messages?
    Can you Ping the robots IP address successfully over the VPN?
  • RoboRuben
    • January 6, 2021 at 4:24 PM
    I can ping the robot and can connect to the webserver. When I try to open the ECHO it says (Pmon-001 Failed to notify PC Monitor,HRTL-061 Ethernet Connection refused). I can see those errors in the error screen of the webserver. The robotcontroller is a v7.70p/53 R-2000iB/210F.
  • HawkME
    568
    3,268
    • January 6, 2021 at 5:05 PM
    1. Are you using Internet Explorer?
    2. Have you allowed Internet Explorer through the Windows Firewall?
    3. Have you added the IP address of the robot to Trusted Sites in IE?
    4. Are you able to use ECHO when local with the robot?
  • RoboRuben
    • January 7, 2021 at 8:27 AM
    1. Yes
    2. Yes
    3. Not possible because my network is controlled by IT
    4. Yes
    Through the VPN I'm able to see the webserver, but once I open the ECHO it fails.
    The VPN uses NAT to modify the IP. Can this have something to do with it?
    Edited 2 times, last by RoboRuben: Aditional info (January 7, 2021 at 9:55 AM).
  • HawkME
    568
    3,268
    • January 7, 2021 at 6:07 PM
    # 3 is required. It is just a setting in your Internet Explorer options menu. Without that it will not work.
    Another option is to try using Chrome instead of IE.
  • RoboRuben
    • January 14, 2021 at 10:33 AM
    Adding it to trusted sites doesn't make it work. Still the same errors. In chrome it just doesn't do anything beside saying "logging in"
  • pdl
    269
    1,531
    • January 17, 2021 at 4:12 AM
    Under the trusted sites setup, do you have active x enabled? Also, are all pop-ups un-blocked? Your trusted sites configuration should basically be as open as possible. When choosing the settings, just ask yourself "what would the IT department do?" and do the opposite.
    If possible, try to completely disable any firewall you may be running. If that works, start re-enabling each program until you figure out the culprit. You will probably need IT assistance to allow you to do this, but I have found that IT folks are happy to help when they can feel useful.
  • Sergei Troizky
    70
    658
    • January 18, 2021 at 8:08 PM
    - Stupid question, but do you have iPendant Controls installed in your PC?
    - If your OS is 64-bit, use the 32-bit Internet Explorer from the Program Files (x86) folder.
  • RoboRuben
    • January 19, 2021 at 11:48 AM
    - yes
    - How do I see which exe is a 32-bit?
  • hermann
    407
    2,612
    • January 19, 2021 at 12:26 PM
    • #11
    Quote from Sergei Troizky
    .. from the Program Files (x86) folder
    If the .exe is in that folder it's the 32 bit version.
  • RoboRuben
    • March 1, 2021 at 1:56 PM
    • #12
    Hey,
    It worked once we put software R843 "remote iPendant" in the robot.
    By buying this software we are now able to connect through port 80 with the webserver. This even while using google chrome.
  • reiddan
    • January 19, 2023 at 7:07 PM
    • #13
    I've had a similar issue with connecting to a robot through a remote VPN connection.
    It sounds like you've already established a connection to the robot through a Siemens switch but are experiencing issues when connecting wirelessly through a remote VPN module.
    You could try switching to a different VPN provider or configuring your current VPN differently. However, another alternative to consider is using a proxy service, which can provide a stable connection and be tailored to your specific needs.
    You can also try private proxies for price tracking as an option.
    Edited once, last by reiddan (January 23, 2023 at 2:29 PM).
  • Sergei Troizky
    70
    658
    • January 21, 2023 at 7:03 PM
    • #14
    Quote from hermann
    .exe files in the (x86) folder are always 32-bit.
  • DonDiZZy
    13
    • June 13, 2023 at 9:20 AM
    • #15
    Maybe ports used by ECHO are blocked through VPN?
  • VPN
