KAREL send system var
  • RoboticsLan
  • December 16, 2020 at 9:47 AM
  • RoboticsLan
    5
    Hello there,
    I have created a socket server (Fanuc robot LR Mate 200iC/5L with R30iA controller) and client on Pc with python.
    $SCR_GRP[1].$m_pos_enb = True
    The server code looks like this:
    PROGRAM tcpserver2
    %STACKSIZE = 4000
    %NOLOCKGROUP
    %NOPAUSE=ERROR+COMMAND+TPENABLE
    %ENVIRONMENT uif
    %ENVIRONMENT sysdef
    %ENVIRONMENT memo
    %ENVIRONMENT kclop
    %ENVIRONMENT bynam
    %ENVIRONMENT fdev
    %ENVIRONMENT flbt
    %INCLUDE klevccdf
    %INCLUDE klevkeys
    %INCLUDE klevkmsk
    VAR
    file_var : FILE
    tmp_int : INTEGER
    tmp_int1 : INTEGER
    tmp_real : REAL
    tmp_str : STRING[128]
    tmp_str1 : STRING[128]
    STATUS : INTEGER
    entry : INTEGER
    posreg : XYZWPR
    my_real : REAL
    ROUTINE get_real(prog_name : STRING;  var_name : STRING) : REAL
           VAR
           entry  : INTEGER
           i      : REAL
           STATUS : INTEGER
    BEGIN
          GET_VAR(entry, prog_name, var_name, i, STATUS)
          IF STATUS<>0 THEN
              WRITE('Error:[',prog_name,']',var_name,STATUS,CR)
          ENDIF
          RETURN(i)
    END get_real
    BEGIN
        -- DISCONNECT the server port BEFORE doing a CONNECT
        WRITE('Disconnecting..',CR)
        MSG_DISCO('S3:',STATUS)
        WRITE('Done.',CR)
        SET_FILE_ATR(file_var, ATR_IA)
        -- set the server port before doing a connect
        SET_VAR(entry, '*SYSTEM*','$HOSTS_CFG[3].$SERVER_PORT',1002,STATUS)
        WRITE('Connecting..',CR)
        MSG_CONNECT('S3:',STATUS)
        WRITE(' Connect Status = ',STATUS,CR)
        IF STATUS = 0 THEN
            -- Open S3:
            WRITE ('Opening',CR)
            FOR tmp_int1 = 1 TO 20 DO
                OPEN FILE file_var ('rw','S3:')
                STATUS = IO_STATUS(file_var)
                WRITE (STATUS,CR)
                IF STATUS = 0 THEN
                -- WRITE an INTEGER
                    FOR tmp_int = 1 TO 1000 DO
                        WRITE('Reading',CR)
                        -- Read 10 bytes
                        BYTES_AHEAD(file_var, entry, STATUS)
                        WRITE(entry, STATUS, CR)
                        READ file_var (tmp_str::10)
                        WRITE (STATUS, CR)
                        WRITE('Succesfull read data from client..',CR)
                        WRITE('Send data back to client..',CR)
                        -- Write 4 bytes (REAL)
                        my_real = get_real('*SYSTEM*','SCR_GRP[1].$MCH_POS_X')
                        WRITE file_var (my_real::9::2)
                        WRITE (STATUS, CR)
                        WRITE('Done sending!',CR)
                    ENDFOR
                    CLOSE FILE file_var
                ENDIF
            ENDFOR
        WRITE('Done.',CR)
        ENDIF
    END tcpserver2
    I am stuck on the following code below. I am trying to send a system variable to the client.
    my_real = get_real('*SYSTEM*','SCR_GRP[1].$MCH_POS_X')    <<
    Can someone help me, please?
    Edited once, last by RoboticsLan (December 16, 2020 at 10:13 AM).
  • R47
    109
    • December 16, 2020 at 12:43 PM
    Hi Roboticslan,
    try this.
    GET_VAR(entry,'*SYSTEM*','SCR_GRP[1].$MCH_POS_X',my_real)
  • RoboticsLan
    5
    • December 16, 2020 at 1:10 PM
    my_real = get_real('*SYSTEM*','$SCR_GRP[1].$MCH_POS_X')
    Lol, I forgot $. Now it is working :smiling_face:
    Thanks for the response tho R47 .
Similar Threads
  • Send active alarm to PLC
    • tomexx
    • May 17, 2017 at 6:12 PM
    • Fanuc Robot Forum
  • motion profiler
    • flavien.J
    • April 19, 2017 at 5:20 PM
    • Fanuc Robot Forum
  • Personal Computer Communications: SEND_DATAPC
    • rastreus
    • March 5, 2020 at 12:06 AM
    • Fanuc Robot Forum
  • Dynamic control of FANUC Robot in Run-Time
    • Gokul N A
    • July 3, 2019 at 10:39 AM
    • Fanuc Robot Forum
  • handling KAREL program pause, which is caused by motion error
    • PeterHsiao
    • May 29, 2020 at 11:28 AM
    • Fanuc Robot Forum
  • TCP Window Update packet for every byte read on socket
    • schnepper
    • November 8, 2019 at 8:24 PM
    • Fanuc Robot Forum
  • KAREL program for weld weave
    • Vlad222
    • November 15, 2017 at 9:46 AM
    • Fanuc Robot Forum
  • world coordinate
  • position robot
  • sockets
  • Socket Message
  • System Variable
  • socket server
