I want to connect a plc to R-30iA, but I don't have profinet. How can I enable inputs/outpus?
I think I have from SDO01 to SDO20 and from SDI01 to SDI22, if those are the ones I could use.
You would get more response posting this on the correct board......MOVED.
Also, there are many posts regarding setting up fieldbus, try using the search function and seeing if a previous post can help get you started.
I suspect you would need to purchase the software option in the first instance.
Welcome to the forum............
