Can IR VISION be setup on the teach pendant or do you have to use the ethernet link on a R30IA controller?
IR VISION on R30ia controller
stein -
May 3, 2018 at 2:31 PM -
I think it can be done on the teach pendant but it is a bit more difficult. A computer is much faster.
Does it take special software? Thank you for the quick reply.
As I recall, the controller will transfer the necessary files. My machines are old enough that they won't connect w/ current IE version - fortunately, I still have a laptop w/ XP.
Some require the supplied MC or USB from Fanuc to be in the controller for the files to transfer to a PC.
Or if you know the version needed you can get them from the FanucCRC website.Also comparability mode is sometime needed for all the tools to function, add the robot IP needs added to your trusted sites list.
How do I find the controller IP address?
Set the IP address of the robot controller.
1 Press MENU
2 From the pull-down menu, select [6 SETUP].
3 Press F1 [TYPE].
4 Select [Host Comm] from the list.
5 Move the cursor to “TCP/IP” and press ENTER.
6 Enter the name of the robot controller in [Robot name].
7 Enter the IP address of the robot controller in [Port#1 IP addr].
8 Enter the subnet mask in [Subnet mask].
9 Enter the IP address of the default gateway in [Router IP addr].
10 Turn off the power of the robot controller, and then turn it back on.
