Error open workcell Roboguide
  • M1chilino
  • August 4, 2020 at 9:37 PM
  • M1chilino
    19
    I need help on Roboguide!!!
    I can't open or create a new cell, the following message appears: "Unable to open workcell, the read-only attributes cannot be cleared."
    How do I solve it?
  • pdl
    269
    1,530
    • August 4, 2020 at 10:24 PM
    Did you install roboguide as an administrator? Are you running roboguide as an administrator? If you answer no to either of those questions, you WILL have issues.
  • massula
    204
    8
    1,427
    Are you running RG as administrator?
  • M1chilino
    19
    • August 5, 2020 at 2:08 PM
    Quote from pdl
    yes I am doing this
    I re-installed, but the error persists
  • M1chilino
    19
    • August 5, 2020 at 2:09 PM
    Quote from massula
    yes, I do
  • Nation
    Typical Robot Error
    538
    1,921
    • August 5, 2020 at 3:58 PM
    Can you try clearing the read only attributes from your cell from windows?
  • TitusLepic
    112
    442
    • August 5, 2020 at 4:20 PM
    Is the workcell in it's default location (C:\Users\userName\Documents\My Workcells)? I've had this problem trying to open a workcell from a network drive before.
  • M1chilino
    19
    • August 5, 2020 at 6:12 PM
    Quote from TitusLepic
    yea. I also can't create a new cell
    no results.
  • M1chilino
    19
    • August 5, 2020 at 6:17 PM
    Quote from Nation
    I clear the attributes, but it still doesn't work. I can't open or create new cell
  • massula
    204
    8
    1,427
    • August 5, 2020 at 6:42 PM
    What is the Roboguide version?
    Are You trying to create a new cell from a robot backup, or from RG default configs?
  • Runis86
    42
    • September 24, 2020 at 4:02 PM
    • #11
    Hi! I have the same issue now, all of a sudden. Do anyone have an update on this issue?
  • M1chilino
    19
    • September 28, 2020 at 2:10 PM
    • #12
    Quote from Runis86
    After searching, I realized that i had this problem after deleting the registry keys from the computer. But the only solution i found at the moment was to format the computer.
  • Runis86
    42
    • October 1, 2020 at 9:53 AM
    • #13
    Okey. Where are those registry keys located by default? Because I am sure I haven't deleted anything. Maybe that location is read/write protected and that is causing this issue?
    Read/write privileges can be changed by the central IT department and since this is a software that is not distributed by IT they have no clue about how their changes might affect Roboguide.
  • mpinar
    • April 25, 2021 at 10:36 PM
    • #14
    I had the same issue. My solution was;
    Go to "Virus and Thread Protection", select "Ransomware protection"
    then set "Controlled folder access" switch to "Off"
  • Ansel@Kautex
    • December 28, 2024 at 7:33 AM
    • #15
    Hi, I got problem on opening the workcell too, and the issue was: my laptop wasn't connect to internet and my default project location is an online OneDrive folder !
    I change the path to a local destination and connect to internet solve this problem.
    Images
      • 577.61 kB
      • 1,600 × 1,200
      • 2
Similar Threads
  • Roboguide workcell built by earlier version cannot be open normally
    • lavaman
    • September 20, 2017 at 12:57 AM
    • Fanuc Robot Forum
  • Roboguide keeps breaking on our computers (can't create a second robot)
    • dohlfhauldhagen
    • March 9, 2017 at 4:31 PM
    • Fanuc Robot Forum
  • workcell
