I am looking for directory where i can change weld_speed for each program.
Weld_speed
m3pisnik -
June 9, 2020 at 11:11 AM -
Hello there,
i think you can combine between Signal and Register for changing this weld parameter.
Change WELD_SPEED under your weld schedule. Data -> Schedules.
If the Arc START instruction is executed before executing the WELD_SPEED motion instruction,
the weld speed defined in the corresponding weld schedule is used.
My weld_speed is in data - > weld scheed but i dont know why use 2 not 1 row.
just write in the weld speed after the arc start instruction. You need to select a schedule when you put in an arc start instruction.
You can write the weld speed into the program when you create it, or change them when ever you want. cursor over to the weld speed.
There will be choices that come up on pendant. put in which ever travel speed you want, we use inches per minute.
