recording video with robot
  • robotik
  • April 30, 2020 at 7:53 AM
  • robotik
    43
    Hello friends
    We wanted to recording video with MH50 robot
    But we have tremors during filming
    This is a vibration for the robot
    Is there a way to minimize this vibration?
    Images
      • 73.22 kB
      • 800 × 800
      • 18
  • 95devils
    235
    8
    1,949
    • April 30, 2020 at 1:51 PM
    Camera with in-body stabilization. Lens with stabilization. Camera body mounted on a multi-axis gyroscope. Larger platform. Larger contact area with the floor.
    Correcting the video in post production could also be possible, unless the video was meant for a live feed with no post.
  • Lemster68
    301
    2,472
    Blog Articles
    7
    • April 30, 2020 at 2:43 PM
    Is that while it is stationary or in motion? Or both? Are you really zoomed in on the subject? That will make it more obvious any vibrations.
  • robotik
    43
    • April 30, 2020 at 7:11 PM
    When we start the servo_on, The robot vibrates at the end of the axis.
    We performed servo_on testing on two robots, MA1440 and MH180
    Vibration on the MH180 is very low
  • 95devils
    235
    8
    1,949
    • April 30, 2020 at 7:15 PM
    Quote from roohparvar
    Bolts tight? Everything mechanically tight inside and out? If so, possibly the servo gains are incorrect. Is the controller initialized with the correct dash number robot. SYSTEM INFO, VERSION versus the name plate model of the robot.
  • robotik
    43
    • April 30, 2020 at 7:24 PM
    The bolts are tight.
    Yes. Everything is mechanically strong inside and out
    If you put a bottle of water on the axis of a robot and then start SERVO_ON, you will see vibration....
  • TSGIR
    81
    715
    • April 30, 2020 at 11:06 PM
    Please share a video to show your means.
  • robotik
    43
    • May 2, 2020 at 9:12 AM
    share a video
    Files
    Record_2020_05_02_11_39_29_879.mp4 3.15 MB – 53 Downloads
  • Robodoc
    56
    7
    1,061
    • May 2, 2020 at 3:21 PM
    First of all you have to understand how robotic servo systems work. In a Yaskawa robot the servo system is a closed loop. The system tells the amplifier how much power to output, this in turn moves the motor that is attached to an encoder. The encoder feeds the signal back into the system that then checks if the direction and speed are correct and changes any data to make it go faster or slower. If the servo power is on, but the motors are not told to move the axis of the robot "float". Because there is no command to move and the encoder says the motor is in the correct position and the system stops sending commands to the amplifier, however, gravity pulls on the weight of the arm causing it to drop. This in turn moves the encoder that tells the system is is not in the correct position and the system then sends a signal to the amplifier to correct the positions and the whole sequence starts over again. The closer you get to an object the more obvious this "hunting" is. Just like in your video, as the camera gets close to the glass and stops, the system hunts for it's position and you can see the "shake".
    Robots are not meant to hold a camera in a 100% stopped position. Robots are meant to move to a spot, go a job and move on. This job could be picking up a part, spot welding, painting.... all of witch don't care about a .5mm wobble, however, a camera is unforgiving and will show every little move, shake or hunt for a position.
    Robodoc
  • recording video
