  4. Kawasaki Robot Forum
Creating Kawasaki Robot backup for RS006LA
  • Mohammed Alrawni
  • February 18, 2020 at 10:25 AM
  • Mohammed Alrawni
    8
    Hi all ,
    i'm trying to create backup for my E01 controller , as i will be connecting Kemmpi welding machine
    i forgot the steps ,,and i searched on all the manuals but no point
    what i did :
    from save/load option ,i saved all the data into usb
    i typed on the aux page 894 it open CF image backup function , but i couldn't select the usb
    any help will be appreciated
  • Go to Best Answer
    kwakisaki
    694
    4,765
    • February 18, 2020 at 11:21 AM
    Welcome to the forum...………:beerchug:
    Using the save/load option in Aux 02 creates the necessary backup information for restoration in the event of user data and system setting data loss.
    - So what you have done already using that option would have saved the required data - based on your file save data selections.
    Aux 0894 only displays the relative arm information, configuration and software versions.
    - There is no other function with 0894 as far as I'm aware (unless they have added a CF image backup function).
    - But I would be surprised if they have, and if they had, I would expect it to be within Aux 02 section.
    Can you provide any screenshots of Aux 0894 and also the listing displayed in Aux 08 Menu?
  • Alexandru
    49
    407
    • February 18, 2020 at 12:11 PM
    you can save the backup from the robot also if you connect the laptop via Ethernet. Connect with KRterm and type save backup.as for example :smiling_face:
    When you plugged in the USB, the robot recognized the USB?
  • Mohammed Alrawni
    8
    • February 18, 2020 at 12:52 PM
    thanks for the reply , kindly see the image .
    as i remember there is a way to do the backup you need to use the dip-switch .
    ya i'm connecting the controller to my laptop ,however i'm using Kawasaki new programming softwaer KIDE .it can do the same plue the programming no need to use the notepad .
    now i selected the usb it's okay i did the CF image backup function and the file size is 500 mb .
    this is my first time trying this backup method so will this be enough ?
    kwakisaki
    694
    4,765
    • February 18, 2020 at 1:21 PM
    Cool...…………..I didn't realise that they had introduced that......About time Kawasaki.....:guru:
    KIDE is something developed by KRG (Kawasaki Robotics Germany), you would need to contact them directly for support on that (I think from memory).
    You clearly have on your USB:
    - A full filesave called backup.as (This is the standard backup usually created from Aux 02 Function).
    - An image file called savedata.ddi (This will be the complete image of the CF card).
    So, my question to you, how did you get the .ddi file onto your USB?
    - You must have carried out the CF backup operation already.
    Dipswitches are only used for upgrading firmware, kernel and initialization procedures.
    If you have a full file save and also a CF Image, that is all you require.
    - A CF image should only be used in instances of CF card failure or where instances of AS or SV corruption has occurred.
    - A full file save should be used to restore configuration data and user data, and extract existing data.
  • Mohammed Alrawni
    8
    • February 18, 2020 at 1:55 PM
    • Best Answer
    in replay to your question :
    after entering 894 it opens the CF backup than in file name selection i select my usb , BTW it was by mistake i found out about the CF backup really :grinning_squinting_face:
    the file backup.as i name it that way , i created it from save/load than file type All , so i really hope it got all the data
    i really appreciate the support
    kwakisaki
    694
    4,765
    • February 18, 2020 at 3:57 PM
    You have all the data you would need...…
    There is no other storage medium within the Kawasaki...:top:
    The bonus is the additional CF options, it's been along time coming...
    Thankfully now available...:bravo:
    Could you tell me what revision AS firmware is installed (you will see it in the header of the .as file)?
  • Mohammed Alrawni
    8
    • February 19, 2020 at 7:26 AM
    i took a screen capture i hope it can help
  • Alexandru
    49
    407
    • February 19, 2020 at 8:32 AM
    before you start working with the robot it is better to save an original backup (initial settings), after that to upgrade the AS and servo to the latest version.
    kwakisaki
    694
    4,765
    • February 19, 2020 at 10:38 AM
    Thanks for the AS version information.
    One final question, what version of KIDE are you also using and where did you obtain it from?
  • Mohammed Alrawni
    8
    • February 19, 2020 at 1:13 PM
    • #11
    thanks AL for this advice ,
    the version i have is 0.9.5.8 (64 bit).
    i obtain it from KRG when i visited them more than 2 years ago ,
    i have tried to attach the setup file here but it was not possible
    kwakisaki
    694
    4,765
    • February 19, 2020 at 1:39 PM
    • #12
    Thank you, yes this is the version I have, I did not know if they continue development of it that is reason I asked.
    Also, you have discovered an undocumented menu with R code 894, which is going to benefit other users (including myself) of Kawasaki E/F Controller, so many thanks for this.....:dance2:
    Yes, your level and points may not allow you to attach the file size, I shall add the kide install to the Kawasaki Online Terminal Editors board for users to download.
    Many thanks...….:top:
  • Rustine100
    5
    • April 26, 2021 at 2:52 PM
    • #13
    Hi all, so I know this is an old thread but I would like to add r codes that seems the one you all were looking for :
    89401 : full image backup (ddi image)
    89402 : full image restore
    there are "hidden" codes, meaning no menu access to reach them.
    the controller will reboot during the process.
