Minimum Circle by Yaskawa Robot
  • mitesh
  • December 16, 2019 at 12:16 PM
  • mitesh
    5
    What is the minimum diameter which a yaskawa robot can cut in a laser cutting application with accuracy and repeatability?
  • 95devils
    230
    8
    1,936
    • December 16, 2019 at 1:22 PM
    You would have to refer to the manual for your specific arm. Big difference in repeatability between a GP8 and MH900.
  • mitesh
    5
    • December 17, 2019 at 5:34 AM
    I have MH 50 which is having DX100 controller and I tried to plot a circle with diameter 16mm. Again i tried to plot 12mm diameter but the shape seems to be oval. For both circle i took 8 points to plot a circle.
  • Motouser
    39
    288
    • December 17, 2019 at 8:31 AM
    Maybe you need a CAD/CAM software: in some application for a simple circle you need hundred of points for a good results and the only way to do it is to create a path in a CAD and postprocessing in a CAM.
    I use Eureka but there are tons of programs for robot.
  • mitesh
    5
    • December 17, 2019 at 9:31 AM
    okay,
    But is there any possibility by using teach pendant writing program and achieving the required smallest Diameter.
  • TSGIR
    81
    713
    • December 18, 2019 at 8:11 PM
    maybe you can use Formcut function too. But it is an option and need pay.
  • Robodoc
    56
    7
    1,059
    • December 21, 2019 at 2:32 PM
    Normally a robot can't cut under 10mm dia circles. Anything under 10mm use a drill.
    Robodoc
  • mihaita
    73
    • April 12, 2020 at 5:20 PM
    Quote from asgary64
    hello.how can enable formcut function in motosim?thx.
  • 95devils
    230
    8
    1,936
    • April 12, 2020 at 9:39 PM
    Quote from mihaita
    It’s a paid Yaskawa parameter. If the real controller has it, load the cmos or all.prm.
  • mihaita
    73
    • April 13, 2020 at 1:20 AM
    thank you.the controloller has this option.
  • yearttt
    • April 26, 2020 at 1:31 PM
    • #11
    :smiling_face::smiling_face::smiling_face::smiling_face::smiling_face:
  • Yaskawa dx100
