HOW TO CONFIGURE IOSYS.IN DEVNET FILES FOR DEVICENET COMMUNICATION BETWEEN A KUKA KRC2 ROBOR AND 4 WAGO MODULES. HELP
HOW TO CONFIGURE IOSYS.IN DEVNET FILES FOR DEVICENET COMMUNICATION BETWEEN A KUKA KRC2 ROBOR AND 4 WAGO MODULES. HELP :(
Reyner Berbesi -
August 27, 2019 at 2:40 AM -
Please check your caps lock first. I think it's blocked.
This has been covered many times. Just use forum search to find those topics and ask for help if you get stuck.
si ya lo hice amigo, avance un poco pero estoy perdido con el archivo iosis.in a la hora de declarar las entradas y salidas..
oye de verdad disculpa el ingles es que no hablo ese idioma y tengo que traducir
Fabian translation
I did it already (the search I guess) I went forward but I'm a bit lost with the iosis.in file and the point where I have to declare the I/O
In the IOSYS.ini there is commentary which tells you where to put your declaration, And if i am remembering right at the bottom of the file there is more information about the declaration itself
maybe this helps
Did you read the READ FIRST topic? If so, you would know that we would need to know your hardware configuration and KSS version, at minimum, in order to be able to help you.
hello, here are the images of the wago modules and the iosys.in file
configure them that way I hope they correct please.
there in the picture shows the error
Iosys.in
...seriously? You expect people to reverse-engineer your entire setup from some photographs?
Provide INFORMATION, not pictures. KSS version. Which KRC DeviceNet option you're using. How many DeviceNet nodes, which MAC-IDs, what baud rate, cable lengths, cable termination, supply voltage wiring. System files and wiring diagrams.
Devnet
Excuse me friend, it's my first robot.
kss 5.5.14
4 nodes
the robot would be the master and the 4 slave modules
connected to the MFS target
Devnet
Well, that answers 2 out of my 7 questions.
