FANUC smoothing with radius (not CNT)
  • Vlad222
  • October 28, 2018 at 7:05 PM
  • Vlad222
    161
    Hi!
    I need smoothing for movements with radius. I use CNT but the physical meaning of CNT is the percent of desired velocity required at waypoint.
    And the positioning error while using CNT is unknown. Where can I find smoothing with radius? Something like CDIS in KUKA.
  • Nation
    Typical Robot Error
    546
    1,924
    • October 28, 2018 at 8:44 PM
    I beleive you have to have the advanced motion package, but with that you can change your termination type to CR, which stands for corner radius.
  • Vlad222
    161
    • November 1, 2018 at 12:59 PM
    We use option Advanced motion package.
    I still have perfomance issues on my trajectories so i made test programs with 3 trajectories with Timers to understand how CNT and CR works.
    On the first screenshot i show 3 trajectories, first left contains 2 points, distance between them is ~800mm
    2-nd in the middle slighty longer. It is for understanding how robot will smooth trajectory.
    3-rd in right is the same as first but with 89 points (~ one point for each 9 mm)
    Linear move speed set for 800mm\sec - Data register 11
    CNT setup from Data register 10
    So then my screenshots from Roboguide with result of this timers -
    First trajectory in every case executed for about 1.0 - 1.1 seconds, so if we think with speed 800mm\sec trajectory with 800mm length should be executed close to 1 second. So this 0.05 - 0.1 sec error is normal for acceleration and deceleration.
    But 3-rd I can't understand
    CR100 - means that robot should smooth movement in radius of 100 mm, so at straight line it should move on max possible speed and i need got also about 1.1second for trajectory, but i got 13.44 !!!
    CNT50 ? what its means? 50% of maxumum speed? if so why i got 8 sec and not 2 sec?
    CNT100 ? what its means? No deceleration? Okay, why i got 1.55 and not 1 second as in first trajectory?
    P.S.
    Real robot execute this trajectories same as Roboguide. So test is robust
    For understanding why i need this tests
    I have a task with a lot of points for painting that should executed on high speed like 600 mm/sec - 1000 mm/sec
    And a lot of parts have complex geometry so i need a lot of points on trajectory to make good paint.
    Images
      • 431.77 kB
      • 1,222 × 1,611
      • 65
      • 586.23 kB
      • 1,597 × 1,313
      • 60
      • 486.61 kB
      • 1,604 × 1,291
      • 47
      • 476.56 kB
      • 1,612 × 1,293
      • 27
      • 445.6 kB
      • 1,608 × 1,290
      • 18
      • 495.26 kB
      • 1,605 × 1,302
      • 34
    Files
    trajectory.PNG_thumb 19.8 kB – 285 Downloads cr_performance.PNG_thumb 25.19 kB – 280 Downloads cnt50.PNG_thumb 22.03 kB – 273 Downloads cnt60.PNG_thumb 22.49 kB – 271 Downloads cnt75.PNG_thumb 19.86 kB – 269 Downloads cnt100.PNG_thumb 20.56 kB – 267 Downloads bench_cr.txt 25.31 kB – 22 Downloads bench_orig.txt 25.94 kB – 17 Downloads
    Edited once, last by Vlad222 (November 2, 2018 at 2:08 PM).
  • Fabian Munoz
    133
    Articles
    1,517
    • November 1, 2018 at 5:23 PM
    My understanding on CNT is that CNT100 does not mean 100 mm before
    CNTxx is calculated based on the speed and length of trajectory. In other words, yo have no idea what the value itself means
    You just know that 100 is wide open, 50 is halfway and 0 is almost fine
    Retired but still helping
  • Robo_Eng_13
    26
    432
    • November 1, 2018 at 8:24 PM
    My understanding is that at CNT100, it will round the corner as much as is necessary in order to safely maintain 100% of its current speed.
    CNT50 would do the same allowing it to loose up to 50% of its speed.
    CNT0 would allow it to come to a complete stop if necessary, but does not force a stop like FINE does.
  • Fabian Munoz
    133
    Articles
    1,517
    • November 1, 2018 at 9:26 PM
    which means You (the robot, not you) really have no clue how many millimeters is before of after or whatever
    For me, programming CNT beside common sense is trial and error
  • Vlad222
    161
    • November 2, 2018 at 2:07 PM
    Why robot have so bad performance with CR100 (it isn't CNT, it is CR, we use option "Advanced motion package")?
    Example:
    38:L P[26] R[11:L]mm/sec CR100 ;
    Edited once, last by Vlad222 (November 2, 2018 at 2:13 PM).
  • kluk-kluk
    51
    5
    300
    • November 5, 2018 at 9:01 AM
    I think it is because the speed is not fixed but in a variable.
    Every next line the program will have to check if the variable is changed, so it will stop at the end of each line.
    Try to set the speed with a fixed number.
  • Vlad222
    161
    • November 6, 2018 at 12:08 PM
    Quote from kluk-kluk
    Yes, it's very helpful! 2 sec instead of 13 sec for path with CR100 :beerchug:
    But we still have a question...why robot moves between only 2 points faster than between them with intermediate points (with smoothing CNT100 or CR...)
    I created new topic for this question:
    https://www.robot-forum.com/robotforum/fan…mber-of-points/
  • lemon132
    14
    • May 3, 2022 at 8:28 AM
    Quote from Vlad222
    Example:
    If you don't use constants, controller can't apply the famous "look ahead" feature. Unless you add "LOCK PREG" in your TP program. This line locks the registers so their values can't change during execution. You can also add "UNLOCK PREG" at the end of the TPP for ex.
