VW version C2 KSS reinstalation failed.
  • cian temp
  • July 26, 2016 at 7:41 AM
  • cian temp
    60
    My friend had a VW version C2 Win 95 ver 4.1 , KSS 4.1.7 and would like to upgrade to WinXP KSS5.4.14, before doing so is there anything need to look out for? He said he tried once before and got stuck when entering KSS at 10 percent.
    Thanks,
    Edited once, last by cian temp (July 26, 2016 at 8:12 AM).
  • panic mode
    1,296
    13,136
    • July 26, 2016 at 5:03 PM
    you cannot install KSS on VW controller - hardware is different. for VW controller you need to use VSS.
  • cian temp
    60
    • July 26, 2016 at 8:54 PM
    Thanks! Will let him know.
    Leon
    35
    5
    473
    • July 27, 2016 at 10:55 AM
    Well, you can install kss on a Vkrc2. I have three vkrc2 kabinets running kss 4.97 on windows 95. the thing is we let kuka install the software.
  • M.Ozkan
    22
    5
    538
    • July 27, 2016 at 11:44 AM
    Change DSE 3.1 board to DSE IBS C33, upgrade memory to min 256 MB and you can install WinXPE 5.X.X
  • bmike
    62
    • July 27, 2016 at 10:59 PM
    Fluke,
    have you ever done this upgrade? I have asked this question before and one of the members said that it was a big mess but he never explained what problems he had.
    I have a GM cabinet and will be attempting the upgrade this weekend, any suggestions are welcome.
  • cian temp
    60
    • July 30, 2016 at 9:50 AM
    Thank you all for the suggestions.
    My friend installed the KSS for VW and worked, the Robot is fine now.
    Thanks!
