Encoder Error
  • rusher02
  • January 3, 2016 at 4:56 AM
  • rusher02
    Hello everyone, Happy New Year!
    We have a KRC4 Controller with KSS V8.3.1 controlling a KR16 HW Robot. I recently setup a DKP400 2 axis positioner then i halt to this error mesage KSS26004 encoder error. when i start to make any axis move this error shows up.
    thank you in advance for your support. ☺
    Images
      • 1.62 MB
      • 3,264 × 1,836
      • 128
    Files
    20160102_172840.jpg_thumb 19.77 kB – 277 Downloads
  • panic mode
    1,267
    13,033
    • January 3, 2016 at 5:32 AM
    that is only followup message. original was 26005. either way there are several things that could go wrong:
    1. external axes feedback cables faulty or not connected correctly
    2. external axis motor faulty
    3. WorkVisual configuration incorrect
    4. Faulty RDC
    5. controller firmware upgrade needed
  • rusher02
    • January 3, 2016 at 5:45 AM
    Thanks a lot panic mode, ill check on it right away!
  • ZorgCat
    13
    • December 4, 2020 at 12:24 PM
    Hi, I have this exact error on a KR10 R900, after unplugging and then plugging in an encoder cable. And I cannot find a way to reset the error, any suggestions?
  • panic mode
    1,267
    13,033
    • December 4, 2020 at 3:11 PM
    reboot,
    remaster
  • ZorgCat
    13
    • December 5, 2020 at 8:06 PM
    I did, not much had worked but after further investigation, it turned out to be that the plastic encoder plug had fallen inside the robot, when the cable was plugged back in. Not much was holding it in there :frowning_face:
    SkyeFire
    1,040
    9,380
    • December 7, 2020 at 3:15 PM
    That plug is normally reasonably robust, but it is vulnerable to someone inserting the cable improperly rotated and forcing the threads to tighten. And if the plug has been damaged this way even once, it it much more fragile afterwards.
