I would not like to others copy my program source code after handover the robot ,especially the function and library.
Could the KUKA_Encryption protect them ?
Thanks!
Thanks!
Hi,I would not like to others copy my program source code after handover the robot ,especially the function and library.
Thanks!
Yes , this software can protect your src and dat file to be open and copy. I have used it for four month. You only need select your files which need to be protect and the select the options in KUKA Encription Tool ,then it will generate a install file(.exe) which can be installed in KUKA system. It will make your src and data file can't be open!
Thanx!
thx, sounds great.
How about the Price of this tool? I would like to persuade my boss to order one
One thing you want to be careful about, though -- the last time I checked (which was a few years ago), the encryption was one-way. That is, once a module was encrypted, there was no way to decrypt it. So you have to be VERY careful about your source code version control, because once the modules on the robot are encrypted, you won't be able to look inside them to see what source code the robot is actually running.
add function in your library that displays message with version number and revision date
KUKA.Encryption tool approximately 2.500 €
OrangeApps KRL Dotfuscator coming soon for KRC4
thx, sounds great.
I don't know the exact price of KUKA.Encryption tool. Because we buy a robot and order this software by the way. I think it's about more than 1000$.
