Help: ibusdrv.o, dndrv.o, mfcdrv.o drivers on krc1
  • LCotta
  • May 19, 2015 at 12:55 PM
  • LCotta
    Hello, I have some errors on a krc1 old robot, and they are related to bus drivers... I think the files inside [drivers] folder are not OK, because of its very small size... Are these drivers on other folder of the robot in order to replace them?
    Thank you very much
  • the leg
    643
    • May 19, 2015 at 2:57 PM
    what are the errors please
    it will help if tell use them
  • s2007.ravi
    14
    585
    • May 19, 2015 at 3:04 PM
    I am not sure what exact error you are facing. Can you write the exact error message? Did you try to reset IO drivers? Try to check your IO configuration and IOSYS.ini file.
    Sent from my iPad using Tapatalk
  • LCotta
    • May 19, 2015 at 3:42 PM
    Thank you very much for your answers.
    The errors are: Error 1013 "file drivers/ibusdrv.o not found", and Error 1025 "Error Configuration driver E/S ibusdrv.o"
    The file physically exists inside driver folder, but size is only 130 bytes, I dont know if this is OK...
    I tried to disable Interbus on IOSYS, and when I reconfigure I/O, no errors are sent, so I think its because of driver...
    Thank you very much!
    Edited once, last by LCotta (May 19, 2015 at 3:51 PM).
  • SkyeFire
    1,061
    9,465
    • May 19, 2015 at 4:50 PM
    What is the history of this robot? Was it working until recently? Is there Interbus hardware connected to the robot?
    This error message is most often caused by hardware issues on the bus. A corrupted driver is rare, although not impossible.
    Hm... an old KRC1 archive I have contains the IBUSDRV.O file, which is 90+kB. This came from a KRC1A running KSS 4.2, if I recall correctly.
  • hermann
    412
    2,629
    • May 19, 2015 at 8:55 PM
    If You have luck the driver is somewhere on drive D:
    May be there has been done a "restore all from floppy" with a uncomplete backup. That can happen if the floppy is complete filled. There were versions of the KSS where no message came after the floppy was complete full. But after a restore there exist files with wrong filesize (mostly 0 bytes). In this case there may be more corrupt files.
  • markopo
    207
    • May 19, 2015 at 9:58 PM
    Hello.
    1. Do You have installed IBS card in robot cabinet ? based on PCI or ISA port ? (fiber optics or copper ?)
    2. Do You have instalation for interbus ( I/O's on master side of robot ) ?
    3. Do You have assigning in IOSYS Interbus configuration file SVC file ?
    Marek
    Edited once, last by markopo (May 19, 2015 at 10:28 PM).
  • LCotta
    • May 20, 2015 at 9:36 AM
    Hello, thanks to all of you.
    The robot is a training old robot, so the problem is that it is out of control sometimes... The thing is that I have backups of it when it worked. IBS card is based on ISA Port, and as I said, bus worked ok a few days ago. I tried to restore a backup with IOSYS and INTERBUS ok, but message is clear, I think. Maybe someone opened drivers files and they were overwritten...
    I will try to find drivers on D: , or get them from another robot if I can...
    EDIT: I found drivers on D: unit. I am no expert with krc1, so how can I copy these files to the correct folder? Thank you very much!
    Edited once, last by LCotta (May 20, 2015 at 9:41 AM).
  • s2007.ravi
    14
    585
    • May 20, 2015 at 10:15 AM
    You can navigate to the folder where you need to paste the files like for IOSYS.INI you have browse C>KRC>ROBOTER>INIT and then you can paste the file there. After this, you need to reset the IO Drivers.
  • LCotta
    • May 20, 2015 at 11:10 AM
    Hello!
    Finally I finally solved the problem. It was driver files, as I suspected. I accesed to windows explorer by pressing "ctrl+ESC" on kcp, opened windows explorer and copy/paste drivers from d: unit to driver folder. After a I/O reconfiguration and bus reset, all worked as before.
    Thank you all very very much for your support!!!
    Alex
