Working with CrossComm
  • Vyastrebov
  • April 26, 2015 at 2:20 PM
  • Vyastrebov
    17
    Hello everyone !!!
    Tell me please how to connect to CROSS ... I wrote a code similar to that shown in the topic (https://www.robot-forum.com/robotforum/kuk…ml-and-more/30/) , but it does not work because I do not know how to connect to the Cross ....
    I would be very grateful for the help !!!
  • Vyastrebov
    17
    • April 26, 2015 at 5:39 PM
    Here is another topic related to the CrossComm https://www.robot-forum.com/robotforum/kuk…35095/#msg35095 ... it has a manual, but it is not specified library with which we have to work .... Can somebody tell me what a library is used ....
    Thanks !!!
  • Vyastrebov
    17
    • May 8, 2015 at 6:07 AM
    Hi Everyone !!!
    I got to write a program that reads and writes variables KUKA, but I want to load into memory .dat file entirely ... I think it will help make OpenCloseRedeclare function of the library PrimaryInterOp.Cross3Krc.dll..... The other day going to check ... Who knows anything please help !!!
    Thanks in advance !!!
    panic mode
    1,293
    13,122
    • May 8, 2015 at 11:43 PM
    Hello V.
    Personally, I have never played with CrossComm or OpenShowVar, maybe if I ever get some spare time (provided access to robot and interest to do so).
    For paid job, I would consider standard route (bite the bullet and buy software option like EthernetKrlXml or RSI or OPC)
    What is the KSS you need to communicate with? There seem to be different version of libraries (even in links you posted).
    It looks like on KRC1, KRC2 library is OCX file but on KRC4 it is the PrimaryInterOp.Cross3Krc.dll?
    No mention about compatibility or if same can be used for different controller versions...
    Either way, when writing own application, one must reference used library before it can be accessed.
    In VB6 it was Ctrl+T and picking registered library from list. To register OCX for example one can use regsvr32 command.
    In Visual Studio (VB.NET for example) same applies but access method may be different (browse folders till DLL is found).
    Then you need to create and initialize object etc. For VB6 this is shown in"Developer documentation CrossCommEXE V1.D1".
    Good luck
  • Vyastrebov
    17
    • May 10, 2015 at 9:20 PM
    Quote from panic mode
    Hello V.
    Good luck
    Thanks for the answer !!! I have solved the problem :icon_smile: Instead of copying the whole, I found SetVarDP function that changes the value of a global variable is not even ... In this function, further specifies the path to the file ...)))
    I just KRC2 and uses PrimaryInterOp.Cross3Krc.dll...
  • diglo
    7
    142
    • November 30, 2016 at 11:47 AM
    Hey people,
    I know this is an old discussion, but I'm looking for some documentation on how to interface directly to CrossComm, on KRC4... (currently i'm using KUKAVARPROXY)
    Can you help me, Vyastrebov?
    diglo
    Edited once, last by diglo (November 30, 2016 at 12:13 PM).
  • boertjie
    5
    • February 28, 2017 at 7:00 AM
    Good day
    Please help me to get the manual for the openshowvar and opencrosscomm.
