End effector interface
  • Plc_User
  • September 12, 2014 at 2:04 PM
  • Plc_User
    297
    In a R30iA-cabinet, where is the end effector interface connected to?
    Which electriconic print, and where is it situated in the cabinet?
  • Racermike123
    13
    901
    • September 12, 2014 at 2:29 PM
    The EE cable ends up terminating through the Pulse cable connection at the Servo Amplifier.
    Unless you have an LR mate.
  • rf103
    17
    264
    • September 13, 2014 at 11:40 AM
    Quote from Racermike123
    Where does it terminate then? :smiling_face:
  • Racermike123
    13
    901
    • September 13, 2014 at 3:22 PM
    I would have to look at a manual. I am guessing that you have an LR Mate correct? Why do you need to know this information?
  • rf103
    17
    264
    • September 13, 2014 at 9:40 PM
    I was just curious. Seeing as you singled out the lr mates.
    Didn't mean to hijack the thread.
  • Racermike123
    13
    901
    • September 16, 2014 at 2:51 PM
    At connection CRM82 located on the main cpu.
  • JD_Mid-State
    Controls
    • July 27, 2022 at 11:27 PM
    How do you configure ethernet to EE
  • pdl
    270
    1,533
    • July 28, 2022 at 1:28 AM
    Are you referring to the actual "EE" connector? If so, you can't. If you need ethernet by the EE connector, the robot has to be ordered that way, or retrofitted.
    If your robot already has it, there will be an ES1 port at the back, and an ES2 port on the end of arm break out panel. They are D-Coded M-12 connectors.
    What model of robot and controller do you have?
  • Erik Olsen
    54
    5
    177
    • July 28, 2022 at 7:33 PM
    Or a Scara, and I think the Delta robots?
  • Sergei Troizky
    70
    658
    • July 28, 2022 at 9:32 PM
    Quote from JD_Mid-State
    "Ethernet" does not specify the communication protocol.
    If you are using industrial one (e.g. Ethernet/IP), you can directly interconnect desired digital inputs to robot outputs.
  • JD_Mid-State
    Controls
    • August 1, 2022 at 9:02 PM
    • #11
    We have an IO block on the EOAT i was wondering if i could run this ethernet back to the controller on port b where as the plc network comes into port a. I wasnt sure if the other ethernet port inside the controller could be configured in this manor or even what the second port is even used for? More specifically our plc comes into CD38A and i was wondering if i could hook into the same network on CD38B
  • HawkME
    568
    3,268
    • August 2, 2022 at 2:34 AM
    • #12
    I believe each port must be on a separate subnet. What comm option do you have installed on the robot?
