KRC1 kr125
the robot can not open. Failure is this! I dont know what is this? if your any idea...
krc1
RoboterTurkey -
June 23, 2014 at 4:38 PM -
The message suggests your KSS version does not fit to your VxWorks Uploader version. How did you get this message? Was there a upgrade/downgrade involved? What did you before this error appeared?
Fubini
Hello.
Could be problem with MFC card where VXWorks is stored. Which system of KSS or VKSS are You using?
For me for the first install KSS then change MFC card. There is problem with shared memory sooo should be problem with mainboard or ... simply some problems with PCI socket. Try to remove card clean socket and on the MFC card clean slot.Marek.
I cleaned mfs card and the fault gone. but i have new faults. i attached images. RDW card, sockets, cable, wires are ok. i cant changed the machine data. anybody help me?
These errors are similar to those which appear when the robot can't communicate to the RDW.
RDW failure or bad cable connections are usual suspects. You mentioned you did something with the MFC? I've had an issue with the RDW connection on here in the past, it's one of the ribbon cables, maybe that's not seated correctly.
Hello.
Check communication with RDW card. On KRC1 You have application in KSS to check comm with RDW. There You have writen values from each axis.
This program is located in Servis Tab (I don't remember well correct tab, check out it), MS-Dos application.Marek.
hello, did you have a correct backup archive file? if so, you can try restoring the correct archive file into your robot. After that, reboot the system and check again!
Thanks all! the problem is solved. I changed dse board and it's work.
