robot won't move in startup mode?
  • wes_mcgee
  • May 10, 2014 at 6:35 PM
  • wes_mcgee
    271
    Got some new KR60s going in, but can't get them to move. Project is fine, no errors showing, robots are mastered(this was done at factory). When I pull enabler, the axes light up, when I press jog the servos come on, and then immediately motor overtorque and brakes on. The are still in the transport position, not that that has anything to do with it. I have never run into any issues with my other KRC4s, but wondering if 8.3 has some other setting(I am quite sure it doesn't , I use 8.2). I checked there are no workspaces or anything set(this would give different error). Its seems like the brakes aren't releasing to me.
    Thoughts?
  • eusty
    721
    • May 10, 2014 at 9:53 PM
    Is the safely configuration ok? I've seen similar when there is an error due to a mada change etc
    Sent with Tapatalk.
  • panic mode
    1,280
    13,083
    • May 11, 2014 at 2:22 AM
    do you hear brakes clicking when using enabler?
    what are the numbers of displayed messages?
  • wes_mcgee
    271
    • May 11, 2014 at 4:44 AM
    There were no displayed msgs except motor overtorque. Yes the brakes were clicking. The cause has been determined however. Lets just say you can't idiot proof everything ;).
    SkyeFire
    1,052
    9,427
    • May 12, 2014 at 3:09 PM
    Oh, c'mon, don't just tease us with that! Tell us what happened! :toothy9:
    Leon
    35
    5
    471
    • May 14, 2014 at 2:29 PM
    Never heard of the saying: "Whenever you make something idiot proof, along comes another idiot." :uglyhammer2:
    SkyeFire
    1,052
    9,427
    • May 14, 2014 at 7:49 PM
    I use the saying on a regular basis. I want to hear this particular story from Mr McGee.
  • benjamin.lundgreen
    48
    • May 14, 2014 at 11:15 PM
    With this teasing you really have to tell us what happened! :icon_wink:
    I once managed to pull off the motorcable for A2 while programming, because of some maintenance guys who had loosened a metal plate and cable clamps inside the carousel without tightening back.
    The cables of course got stuck around plate and the rest is history.
    I hope this problem that you have didn't cause any damge and it would be interesting to hear more about it :smiling_face:
  • wes_mcgee
    271
    • May 22, 2014 at 6:41 AM
    two robots, rapidly installed in one cell. encoder cables crossed between them! Repeatedly checking that pins were good, etc. but not checking that controller A motor and encoder both go to robot A!
  • panic mode
    1,280
    13,083
    • May 22, 2014 at 2:13 PM
    sweeeeet... :beerchug:
    SkyeFire
    1,052
    9,427
    • May 22, 2014 at 4:37 PM
    • #11
    Heh. I've done that.
    Once had an 11-axis KUKAbot, which requires two RDC cards. But only the first RDC keeps the data for robot serial #, mastering, etc. So when someone swapped the cable ends, it looked like a a blown RDC or damaged DSE-RDC cable.
    Another fun one is when someone swaps around motor/resolver cables on the same robot. This usually happens to me without anyone telling me that any changes were made, which results in a robot that ran perfectly when I left it on Monday night being completely inoperative on Tuesday morning ( :waffen100: night shift :hammer1::mad:)
Users Viewing This Thread
  • 1 Guest
