Any install ceiling experience for KUKA KR125/2 KRC1?
  • najafabadi
  • April 7, 2014 at 9:38 PM
  • najafabadi
    56
    Hello everybody,
    Any ceiling installion experience for KUKA KR125/2 KRC1? I'm just curious about the possible problems may happen.
    Documents show that ceiling installation is possible.
  • M.Ozkan
    22
    5
    538
    • April 7, 2014 at 9:48 PM
    If this robot normally floor mounted, ceiling or another mount type it's not possible.
  • SkyeFire
    1,062
    9,465
    • April 7, 2014 at 11:51 PM
    As Fluke says, there are hardware differences between a Floor and Ceiling mounted KR. The main one (that I know of) is that the counterbalance must work in the opposite direction to counteract gravity. On some models, it may be possible to swap the counterbalance and perform the other changes in software, but I can't speak to the KR125 specifically.
    Aside from that, things are fairly normal. If I recall correctly, setting the robot as Ceiling mount rotates $WORLD such that Z+ is still "up".
    Swapping out the A1 motor becomes a serious pain. Reaching the RDW connector for the EMT becomes an adventure as well -- a scissor-lift or similar device is just about required.
  • najafabadi
    56
    • April 8, 2014 at 3:23 PM
    Thank you.
    Data sheet shows it is possible (see attachment)!
    Files
    kr125_2.pdf 63.68 kB – 53 Downloads
  • SkyeFire
    1,062
    9,465
    • April 8, 2014 at 3:26 PM
    No, the spec sheet says that the robot can be purchased with that option. That's not the same as saying that the same robot can be moved from a Floor mount to a Ceiling mount.
  • the leg
    643
    • April 10, 2014 at 7:33 PM
    only a counter balance and change and mada
    we have done one before due to incorrect spec being ordered
  • najafabadi
    56
    • April 14, 2014 at 2:40 PM
    Thank you. If possible please let us know more details.
  • the leg
    643
    • April 14, 2014 at 2:43 PM
    You need to order the correct counter balance fie a ceiling mount from kuka I don't have a part number but it might just be the pressure I will check later
    Sent from my Nexus 5 using Tapatalk
  • najafabadi
    56
    • May 2, 2016 at 8:13 PM
    Last friday I visited mercedes benz factory in Bremen. At the end of press shop there are 2 KRC1 KR125 robots that installed on the ceiling and handling the parts to conveyor. Unfortunately no one there to answer technical questions about counter balance. Also taking photo was forbidden during the visit.
    If anyone wants to see them can booked a factory visit from the link http://www.bremen-tourism.de/mercedes-benz-factory-tour-bremen
    They show you only press and trim shop.
