Safely remove usb
  • GillesG
  • March 19, 2014 at 1:55 PM
  • GillesG
    39
    I getting further in my erasmus project and now i'm putting programs on the robot, but when i want to remove a usb from the krc2, how can i do it safely?
    Greeting
  • sasif
    17
    • March 19, 2014 at 1:57 PM
    go into the Windows mode and right click on status click on usb icon and remove the usb.
    http://safelyremove.com/fullFeaturesList.htm
  • GillesG
    39
    • March 19, 2014 at 2:19 PM
    It is on the teach pendant, so right clicking does not work
  • sasif
    17
    • March 19, 2014 at 2:26 PM
    then attach monitor and mouse with the controller PC and you can do stuff there easily.
  • GillesG
    39
    • March 19, 2014 at 2:29 PM
    There already is an extra monitor attached to the krc2, but its not like the "real" windows. There is no homescreen were i can see the usb in the corner right under
  • eusty
    721
    • March 19, 2014 at 2:44 PM
    TBH I just removed them, it's never been an issue.
    It possibly has Quick removal selected in the Windows properties so write caching is disabled. It makes sense as there is no easy way to safely remove it and performance isn't an issue.
  • GillesG
    39
    • March 19, 2014 at 2:48 PM
    Ok, thx i'll try to convince my boss, he is a little older and thinks the robot might explode when you dont remove it safely
  • eusty
    721
    • March 19, 2014 at 2:53 PM
    Tell him it will be fine....but needs to stand on one leg to insert it due to "grounding issues"... :fine:
  • GillesG
    39
    • March 19, 2014 at 3:24 PM
    He asked me if i take it out with my right hand do i have to stand on my right or my left leg??
  • panic mode
    1,264
    13,031
    • March 19, 2014 at 4:20 PM
    I just yank the USB key out after 3-4 seconds, never had a problem (from robot).
    edit -----
    on a laptop, I have to eject it safely or the stick will likely be corrupt (IT does not understand what is meant by disabling delayed write)
    Edited once, last by panic mode (March 20, 2014 at 1:20 PM).
  • sasif
    17
    • March 20, 2014 at 12:26 PM
    • #11
    I always remove USB safely from the Controller computer though. I usually click twice on the time on controller pane which allows me to see proper normal window desktop. If you can't see USB sign in status pane then you can goto My Computer and right click the USB and select Eject.
  • neranol
    33
    • March 22, 2014 at 5:40 PM
    • #12
    By default USB sticks are configurastes for fast ejection. I can remove USB and normally nothing is going to happen. But if, in Windows, you change prop. From USB for "performance", you have to eject it.
    Neranol
