Hi. I recently purchased one k125 with krc1 . I need to test the robot so i have made the conections on X11 to make stand alone operation and to get rid of error messages.
All starts no error messages and ( I ) is always on. When i try to jog the robot in T1 mode nothing appens but thw momwnt when i press the button in kcp1 2 relays conect. I dont hear the brakes off motors and no mevement also.
Can someone try to help me please.
krc1 robot dont start
quati -
November 21, 2013 at 2:22 PM -
no message appear ?
Nothing appears on error messages
Sent from my GT-I9505 using Tapatalk
I hear inside of power suplly 1 contactor when i press the key on kcp1 then when i also press the axxis to move nothing happens....
Is the system in T1 mode?
Is jogging enabled? Is Jogging in key mode or mouse mode? (Icon on left of screen, second(?) from top, above the red running man)
What is the jog speed setting?
It is in T1 mode and jogging in key mode ( when i press the key of kcp1 appears the axxis to move on right of screen)Speed of jog 100%.
The conections i made on x11
Hey quati, is this compatible with KRC2?
Can you post some more details please? -
I dont know ... i think yes. Well i found that my leds from enable and brake are all disconected....any ideas
Thats good, can you please share this document? I also need the same plug at the moment to exclude the external stop...
I have led ready off on power module. Send me email i will reply.
Its solved...
Enviado do meu GT-I9505 através de Tapatalk
Thats good, can you please share this document? I also need the same plug at the moment to exclude the external stop...Service Plug for KRC2 is in the download section
Its solved...Enviado do meu GT-I9505 através de Tapatalk
Friend, what you did to solve this problem? I'm having the same problem. Thanks for the help.
- I think you worked through your issue,
But for future reference... Here is the official X11 Wiring diagram
yes.... for GM style KRC1.
but there are also variants like VW, standard Kuka etc.
For standard KUKA one can use one shown here:
https://www.robot-forum.com/robotforum/kuk…52695/#msg52695One for KRC2 has few additional connections and should work on both KRC1/KRC2 if one adds jumper 37-40 (0VDC for EStop relays).
