After creating a cube interference, the specify output, SOUT #081 does not come on. Normally this output comes on after I've created a cube zone using the max/min method which is positioning the manipulator far upper left corner and then lower right corner. After creating this method I press modify for each, max/min, but the output still does not come on, so my table when needs to sweep in and out slams all the way with the stop block near the proximity switch, which tells me the decelerator for A-B side is not coming on all at. Does any one, surely run in to this could give me some feedback.
PS, I am in working on a MRC controller, Robot SK6 Arc Weld II Unit.
