Axis 6 pellet broken on kuka robot
  • moncef
  • March 20, 2024 at 1:39 PM
  • moncef
    hello dears,
    We have a KUKA robot which the pellet of axis 6 is broken, the calibration of the axis 6 is impossible with semd tool.
    Can we change it or we must change completely the arm ?
    In attached image the 'pellet' component broken.
    Many thanks
    ?thumbnail=1
  • MOM March 20, 2024 at 2:02 PM
    Approved the thread.
  • MOM March 20, 2024 at 2:03 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum.
  • panic mode
    1,266
    13,032
    • March 20, 2024 at 4:19 PM
    not sure what is meant by "pellet" in this case, mastering cartridge or pin perhaps?
    and what is the robot mode?
    SkyeFire
    1,039
    9,375
    • March 20, 2024 at 9:30 PM
    Quote from moncef
    It is possible to perform "Dial Mastering" instead of EMD Mastering. However, it will be difficult to achieve equivalent levels of accuracy. Without a vernier mark, it will be hard to visually align A6 correctly.
    It may become necessary to Dial Master A6 as accurately as possible, then re-teach path points where that was not accurate enough. Once you have established your new Mastering location, add a vernier mark (paint, scribe line, something) to make it possible to re-master in the future.
    It would not be necessary to replace the entire arm, just the wrist.
    Quote from moncef
    That image is not displayable, for some reason.
  • moncef
    • March 21, 2024 at 11:35 PM
    Hello dears,
    Thank you for your feedback, i mean by ''pellet'' the pieces for calibration with a cork on each axis.
    we received a new one spare part from kuka, there is a threaded part for the cork and other one installed on robot.
    we didn't know if we can replace it without risk and what's the changing procedure ?
    Many thanks
    SkyeFire
    1,039
    9,375
    • March 22, 2024 at 3:15 PM
    Quote from moncef
    The Mastering cartridge requires some careful handling, but changing it is not very risky mechanically -- it just requires care. There are precision machined surfaces you need to take care not to damage.
    The main issue is that each cartridge is fine-tuned on the robot at the factory before the robot is shipped. So your new A6 Mastering position may not precisely match the original. Worst case, you may need to touch up some points.
  • Lemster68
    295
    2,453
    Blog Articles
    7
    • March 29, 2024 at 1:42 PM
    This is the code for that link if it will help to figure out what the problem is.
    <img src="https://www.robot-forum.com/attachment/395…pg/?thumbnail=1" width="352" height="198" alt="?thumbnail=1" class="">
  • KUKA KRC4
  • broken
  • axis 6 robot
