Hello. I have been trying to activate the EE pins of the robot using the RO registers, but I have not had success. I have already read the manuals and watched some videos, but nothing seems to help me. Does anyone know a little about the subject or have any documents that can help me?
Control the EE pins using the RO registers
ANDRES_MNTS -
March 20, 2024 at 3:14 AM -
Nation
March 20, 2024 at 4:22 AM Approved the thread. -
What arm type? What controller generation?
ROs made the change from sinking to sourcing outputs a while ago.
We are working on a LR MATE 200iD with a controller "R-30iB Mate Plus"
RO 1 - 6 Typically control internal solenoids that are plumbed to the 1A - 3A and 1B-3B ports.
RO 7 & 8 Are wired to the connector.
Yeah, we were traying to activate the RO7 and RO8, but it seems to do nothing...
What we want to do, is to send a signal from that RO to a external device to confirm the start of the program and activate the tool that our robot has.
RO7 and RO8 are controlling the signal status of the associated pins on the EE-connector.
So for instance when RO7 is turned ON, pin 7 in the EE-connector will be energized with +24VDC.The amount of current available for the RO-signals are however limited to max 200mA.
Maybe your fuse has blown?
RO (robot outputs) are used for robot tooling. They are not used to send signals to external devices other than tooling. Sounds like you need to use Digital output ---DO
What I did, was to get into the I/O configuration, and in a "interconnection" option, i convert the DI to RO, so I can control the RO with external signals.
Now, i need to activate them with a program in ROBODK. Im controlling the robot with Ethernet, but when I run the code, it doesnt activate the led I have connected it RO7 and in RO8, even though im activating the external signals. When I simulate the DI activations for does 2 especifir signals it works.
Did you enable the interconnections? How do you control the DIs and are they really working?
Put a voltage meter between the RO 7 pin and the pin 12, 0v. Then manually toggle the RO and see if it shows voltage.
