  4. ABB Robot Forum
IRB 1400 not jogging
  • Kim Bak
  • March 19, 2024 at 8:40 AM
  • Kim Bak
    Hello there. :smiling_face:
    I have this IRB 1400 robot.
    When i turn it on it makes no Faults.
    when i push the button on my teach pendant, the fault 37001 coms up.
    KM3 is pulled when i power up the robot when i push teach pendant KM1 is pulled and pulled off again
    Do any have a easy way to test the contactors or can exsplain how they works
    I know KM1 and KM2 need to be pulled together within 300msec
    Regards Kim Bak
  • Viperacebb
    5
    26
    • March 19, 2024 at 2:22 PM
    Good day! I've seen this happen in the past. I would put a meter on the 24VDC side of the contactor to see if it's maintaining the 24VDC, even once the contactor let's go. It's possible that the safety board is acting up, releasing the 24VDC from the contactor following the motors on request. Are all the safety chains illuminated? Are there any other faults coming up prior to this fault? Once you've verified the 24VDC, you should check the 0VDC side as well. This happened to me once and found a bad contact or a loss of 0VDC. Use a known 24VDC as a reference when checking. Just some things to try.
  • Skooter
    169
    2,026
    • March 20, 2024 at 2:24 AM
    Is this an M94A controller? If so, manual is >here<.
    Was this setup running & then suddenly stopped or are you trying to get it running to redeploy?
    If KM2 is not pulling in, then this is an issue with KM2 itself or the Chain 2 (0V) run-chain. Chain 2 is accessed at connector block KT3 row. Double check row 'B' jumpers: 1-2, 3-4, 5-6, 7-8, 9-10, 11-12. Don't assume jumpers are good, pull each one and verify the the were properly inserted and tightened on the wire and not the insulation. KT3 has deeper than normal wire pockets and it's easy to tighten on the insulation if you don't strip the wire back enough. Also don't assume the Chain 2 is good based on the LEDs on the DSQC256A, those LEDs only show status of Chain 1 (24V).
    A bad contact Viperacebb describes is common along with dirty E-Stop contacts. Check the e-stops by cycling the controller and pendant E-Stops about a dozen times each with the power on to help clean the contacts. If it has the old Baco E-Stops, they should be replaced. The replacement numbers are found >here<.
  • Kim Bak
    • April 10, 2024 at 12:07 PM
    Hi Again
    i have no faults on my teach pendant
    I Still have the problem, i have found out that i have a lost 0volt on my relay KM2, the relay is working just fine i have test.
    So i think it is my runchain 2 that is the problem comming from the card DSQT256A, have any tryed this before ?
    robot-forum.com/attachment/39752/
  • Kim Bak
    • April 10, 2024 at 12:08 PM
  • Skooter
    169
    2,026
    • April 10, 2024 at 5:12 PM
    From previous response:
    Chain 2 is accessed at connector block KT3 row. Double check row 'B' jumpers: 1-2, 3-4, 5-6, 7-8, 9-10, 11-12. Don't assume jumpers are good, pull each one and verify they were properly inserted and tightened on the wire and not the insulation. KT3 has deeper than normal wire pockets and it's easy to tighten on the insulation if you don't strip the wire back enough.
    Reference the prints in the manual in the link in previous response, circuit diagram sheets 7 & 8.
    I troubleshoot the 0V chain by putting the voltmeter (+) on the 24V [XT3-b15 or -B16] and use the (-) lead to follow the 0V thru the run-chain. If in manual mode, you must pull in the deadman to measure, I prefer Auto mode so I don't have to mess with deadman.
    Start at XT3-B5 and if it is 0V, then keep going XT3-B6 up to -B12. You'll find the break in the chain somewhere.
  • FSD-Robotics-Radwell
    10
    • April 10, 2024 at 7:23 PM
    Kim Bak,
    Have you tried swappipng the motor contractor with a new one yet? If you need spares we have them instock and every other part for all generations of IRB1400 robot including S4 M94. These motor contactors are a common fail item. Its a very unlikely an internal controller harness or wiring issue unless something was recently changed.
    Let us know how we can help.
    Robot Tech Support Team
    FSD Robotics - A Radwell Company
    Radwell International
    email: fsdrobotics@radwell.com
    http://www.factorysurplusdirect.com
    http://www.radwell.com
  • Kim Bak
    • April 12, 2024 at 7:47 AM
    Hi Skooter
    Thanks for your help it was useful and now the robot is running, it was my collision signal, when i tireed the wires together then the robot runs. :smiling_face:
    But now my IO-card is also lightning red, can that be because i have made a Reboot of the robot.
  • Skooter
    169
    2,026
    • April 12, 2024 at 10:33 PM
    Looks like DSQC315 Combi Bd in board address 1 and DSQC223 Digital I/O in board address 2.
    Try reloading your EIO parameters from a backup.
    If you have to enter manually:
    DSQC315 has 16inputs / 16 outputs / 2 analog outputs
    DSQC223 has 16inputs / 16 outputs
  • Kim Bak
    • May 1, 2024 at 11:19 AM
    Hi skooter
    unfortentlig i have no backup of my old parameter
    How do i add the boards manually ?
  • Skooter
    169
    2,026
    • May 1, 2024 at 5:23 PM
    • #11
    Procedure is found in the User's Guide found here:
    Thread
    BaseWare 2.1 Rapid Reference Manual & User's Guide
    Hope this helps
    Skooter
    December 13, 2017 at 9:54 PM
    See 'Defining I/O Boards'. When you press 'Add', both boards can be selected in a listing. Make sure to change default information if it doesn't match information given in post 9. Don't mess with the Polling Rate.
Similar Threads
  • Changing batteries and updating rev counters
    • SkyeFire
    • November 28, 2023 at 10:58 PM
    • ABB YuMi
