FANUC Pick & Place Offset Issues
  • kualsrb
  • March 5, 2024 at 6:24 PM
  • kualsrb
    8
    Hey everyone! I am currently trying to implement some sort of vision offset pick & place simulation, but currently having trouble where when my program hits line 9, it will do some crazy rotations when it should be moving towards the object to pick it up. I am new to FANUC so I honestly have no idea what is going on and what I have to do.
    I did have an issue earlier with the Offset Data Calculation Tool where I was unable to set a ref. pos. status because the camera will capture at the position where it should be picking up the shell (thus not being able to see the shell itself because the camera is mounted on the robot).
    Anyone know how to solve this problem by any chance? Any feedback will be appreciated. Thank you!
    Video of simulation: Video
    Picture of code: 7OR1sPG
  • Lemster68 March 5, 2024 at 6:33 PM
    Approved the thread.
  • HawkME
    568
    3,268
    • March 6, 2024 at 5:48 PM
    Did you touch up that position after applying the vision offset? Can you show the values of all those positions?
  • Doctor_C
    33
    198
    • March 6, 2024 at 6:52 PM
    Change line 9 to Joint, Line 10 to linear. With offsets and linear it will take the shortest route. By making the line 9 move above a Joint, it will use your taught pose with the offset applied.
  • ROBOT_G
    23
    241
    • March 6, 2024 at 9:05 PM
    If the model is a round object turn the orientation off in the gpm locator
  • kualsrb
    8
    • March 7, 2024 at 4:01 PM
    Thank you all for the reply. For the position, which position are you referring to? Are you talking about my position registers?
    I tried to change line 9 to joint, but I get the error MOTN 017 Limit Error (G: 1, A: 5).
    I have also just turned off the orientation.
  • ROBOT_G
    23
    241
    • March 7, 2024 at 4:18 PM
    After you set reference you need to run the process again to get zero offset then touchup your position that has the VR offset. When it ask to subtract offset it won't matter because it should be zero.
  • kualsrb
    8
    • March 7, 2024 at 4:21 PM
    Here is the picture of the current program and positions:
    6Hfnl8z
    Also, my understanding is that the reference position is the position where the robot arm is inside the object and is ready to pick up the object. Is that true?
  • Nation
    Typical Robot Error
    547
    1,925
    • March 7, 2024 at 5:54 PM
    Is your part really -287mm from where your application frame is taught?
    Quote from kualsrb
    No. It is what will be subtracted from the vision's found position.
  • kualsrb
    8
    • March 7, 2024 at 7:29 PM
    I just measured it and my part is 98mm from the ground. Is this the value I should be putting in?
    Quote from Nation
  • Nation
    Typical Robot Error
    547
    1,925
    • March 7, 2024 at 8:15 PM
    Without knowing where your application user frame is (I believe it is specified in the snap part of the tree, or at the root), I can't answer that. If it the ground, that is correct, but if it is not the ground, it will be wrong.
  • kualsrb
    8
    • March 7, 2024 at 9:59 PM
    • #11
    Made some fixes like all of you have recommended me AND after updating my user frame, the simulation is working properly.
    Thank you all for your help!!!
  • vision error
